I/O Problem
ElectroNick
I/O Problem
PostPosted: Thu Feb 09, 2006 9:23 am     Reply with quote
I'm trying to use PIC16F946, when I define ports as input that's ok, it works. But when I define ports as output that goes high automatically, I try to clear and change it in software but no way, output is always high! Previously I used 16f628, 16f785 etc. without problem. But i can't do it at this time. I also disable LCD module and A/D module like this:
     SETUP_ADC(ADC_OFF);
     setup_lcd(LCD_DISABLED);
     SETUP_WDT(WDT_OFF);
Can you help me?
Thank you.
I use PCWH Compiler
IDE Version 3.233
PCB Version 3.233
PCM Version 3.233
PCH Version 3.233
PostPosted: Thu Feb 09, 2006 12:22 pm     Reply with quote
You need to post a test program that shows the problem. We need
to know what ports you are using when the problem occurs.
ElectroNick
test program
PostPosted: Fri Feb 10, 2006 2:02 am     Reply with quote
This is my test program, but that doesn't work:
#include "16F946.h"
#fuses NOWDT, NOMCLR, PROTECT, INTRC_IO, NOBROWNOUT, NODEBUG, NOIESO, NOFCMEN, NOPUT
#use delay (clock=4000000)
#define   ALL_OUT 0
#define ALL_IN 0xFF
void main ()
   SETUP_ADC(ADC_OFF);
   SETUP_ADC_PORTS(NO_ANALOGS);
   SETUP_WDT(WDT_OFF);
   SET_TRIS_A(0b10101011);
   SET_TRIS_B(ALL_OUT);
   SET_TRIS_C(0b01011000);
   SET_TRIS_D(0b11010000);
   SET_TRIS_E(0b00011111);
   SET_TRIS_F(0b00001111);
   SET_TRIS_G(ALL_IN);
   while (TRUE)
      output_toggle(PIN_B0);
      output_toggle(PIN_B1);
I can't change the port values in CCS but I wrote a simple program in asm and it changes. But I can't write program in asm, it is too difficult to do it.
Is there anyone who can understand the problem?
Thank you.
Einstein
PostPosted: Tue May 30, 2006 6:21 am     Reply with quote
I have the same problem with Ports F and G.
After controlling the generated ASM code from the compiler,
I noticed that the TRIS Register definition of Port F and G was
understood wrong from the compiler. He locates these ports into
register 0xA and 0xB, that is used by PCLATH and INTCON.
I tested it, written the TRIS definition in asm and it works.
I am still trying to understand where to change the memory location/definiton for this device in the compiler.
regards,
AE
PostPosted: Tue May 30, 2006 12:04 pm     Reply with quote
You can write directly to the TRISF and TRISG registers in the 16F946
by using the following method:
#byte TRISF = 0x185
#byte TRISG = 0x187
TRISF = 0xFF;   // All inputs
TRISG = 0x00;  // All outputs
Einstein
PostPosted: Wed May 31, 2006 5:57 am     Reply with quote
I updated by compiler version to 3.249 and the problem was resolved.
THX,
AE
