PIC18F452 vs PIC18F4520
barkerben
PostPosted: Mon May 29, 2006 4:00 am     Reply with quote
I have the student version of CCS for the PIC18F452. I've just realised my new PIC is a PIC18F4520.
Although my compiler was sold as locked to the former, are they similar enough that I can still program it, or do I need a new PIC :-(
Cheers,
Ben
PostPosted: Mon May 29, 2006 6:35 am     Reply with quote
...it looks like the pinouts are the same for both IC's, so channging may not be too hard...
Ben
PostPosted: Mon May 29, 2006 8:17 am     Reply with quote
Be aware that the PIC18F4520 has a huge list of known hardware errata, especially when you want to do something with the SPI or CCP units these chips are troublesome. Have a look at the errata list.
I haven't checked the register files for both processors but my guess is that for simple programs you very likely will get away with compiling for the PIC18F452. For programs more complicated than blinking a led I recommend you buy the correct compiler/processor combination.
Tip: Have you tried asking for a sample?
Storic
PostPosted: Mon May 29, 2006 4:59 pm     Reply with quote
I was not aware of the troublesome list, however I did go from a 4520 to a 4620 without any problems, (I needed to ROM space on my project).
ANdrew
What has been learnt if you make the same mistake? Wink
PostPosted: Mon May 29, 2006 5:26 pm     Reply with quote
Most problems are minor or cover obscure areas like 9-bit serial data transmissions and often workarounds are given so the chips can be used. However when given the choice for a new project I would rather go for a chip with a shorter errata list like the PIC18F6622.
