printf hangs
teekaytk
printf hangs
PostPosted: Mon May 29, 2006 5:44 am     Reply with quote
hi i am using 18LF8720 in 3.3v system. printf command seems to make it hang during strings longer than 10 characters. but putc always works.
has any one found this problem before. is this a bug? or is it just me!
please help
PostPosted: Mon May 29, 2006 6:10 am     Reply with quote
As far as I know this is not a known bug. Which compiler version are you using?
Can you post a small but compilable program showing your problem?
teekaytk
PostPosted: Mon May 29, 2006 6:24 am     Reply with quote
ver is 3.230
#include <18F8720.h>
#device *=16//,icd=true
#use delay(clock=16000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#fuses NOWDT,WDT128, HS, NOPROTECT, NOOSCSEN, NOBROWNOUT, BORV25, NOPUT, NOCPD, STVREN, NODEBUG, NOLVP, NOWRT, NOCPB, NOEBTR, NOWRTD, NOWRTC, NOWRTB
void main (){
printf("initialize done")
while(1){}
code that works
void main (){
while(1){putc(oxAA)}
Christophe
PostPosted: Mon May 29, 2006 6:31 am     Reply with quote
Maybe you can try
printf("%S","TRY THIS");
PostPosted: Mon May 29, 2006 7:03 am     Reply with quote
teekaytk wrote:
code that works
void main (){
You are cheating, I do understand your intentions but both your example codes contain compiler errors. From the given example code I don't understand why it isn't working but as this is not your real program code the error might be somewhere else.
For the PIC18 series this line can be omitted, it will always use 16-bit pointers.
