Problem when modify the rs485 driver rs485.c
Jim
PostPosted: Sat May 27, 2006 11:19 pm     Reply with quote
hi,
I am modifying the CCS driver rs485.c so that instead of having the Format: source | destination | data-length | data | checksum, it will have the following modified format:
Start-of-TX-char| source | destination | data-length | data | checksum
I defined the Start-of-TX-char as '^'.
The problem that I don't see the Start-of-TX-char as the first received character for a giving TXed, but I see the "source". Do you guys have any pointer? Here is the modified code from rs485.c. I am using PCH 3.228 and PIC16F876 and PIC16F628A ( the CCS RFID development kit)
#ifndef RS485_DRIVER
#define RS485_DRIVER
#ifndef RS485_ID
#define RS485_ID  0x10                 // The device's RS485 address or ID
#ifndef RS485_USE_EXT_INT
#define RS485_USE_EXT_INT FALSE        // Select between external interrupt
#endif                                 // or asynchronous serial interrupt
#if(RS485_USE_EXT_INT == FALSE)
   #ifndef RS485_RX_PIN
   #define RS485_RX_PIN       PIN_C7   // Data receive pin
   #ifndef RS485_TX_PIN
   #define RS485_TX_PIN       PIN_C6   // Data transmit pin
   #ifndef RS485_ENABLE_PIN
   #define RS485_ENABLE_PIN   PIN_B4   // Controls DE pin.  RX low, TX high.
   #ifndef RS485_RX_ENABLE
   #define RS485_RX_ENABLE    PIN_B5   // Controls RE pin.  Should keep low.
   #use rs232(baud=9600, xmit=RS485_TX_PIN, rcv=RS485_RX_PIN, enable=RS485_ENABLE_PIN, bits=9, long_data, errors, stream=RS485)
   #use rs232(baud=9600, xmit=RS485_TX_PIN, rcv=RS485_RX_PIN, enable=RS485_ENABLE_PIN, bits=9, long_data, force_sw, multi_master, errors, stream=RS485_CD)
   #if getenv("AUART")
      #define RCV_OFF() {setup_uart(FALSE);}
   #else
#else
   #define RS485_RX_PIN       PIN_B0   // Data receive pin
   #define RS485_TX_PIN       PIN_B3   // Data transmit pin
   #use rs232(baud=9600, xmit=RS485_TX_PIN, rcv=RS485_RX_PIN, enable=RS485_ENABLE_PIN, bits=9, long_data, multi_master, errors, stream=RS485_CD)
   #define RCV_OFF() {disable_interrupts(INT_EXT);}
#define RS485_wait_time 20             // Wait time in milliseconds
#bit    rs485_collision = rs232_errors.6
#ifndef RS485_RX_BUFFER_SIZE
#define RS485_RX_BUFFER_SIZE  40
int rs485_state, rs485_ni, rs485_no;
int rs485_buffer[RS485_RX_BUFFER_SIZE];
[b]static int8  msg_hearder = '^'; /* start of the message char */[/b]
// Purpose:    Enable data reception
// Inputs:     None
// Outputs:    None
void RCV_ON(void) {
   #if (RS485_USE_EXT_INT==FALSE)
      while(kbhit(RS485)) {getc();} // Clear RX buffer. Clear RDA interrupt flag. Clear overrun error flag.
      #if getenv("AUART")
         setup_uart(UART_ADDRESS);
         setup_uart(TRUE);
      #else
         setup_uart(TRUE);
   #else
      clear_interrupt(INT_EXT);
      enable_interrupts(INT_EXT);
// Purpose:    Initialize RS485 communication. Call this before
//             using any other RS485 functions.
// Inputs:     None
// Outputs:    None
void rs485_init() {
   RCV_ON();
   rs485_state=0;
   rs485_ni=0;
   rs485_no=0;
   #if RS485_USE_EXT_INT==FALSE
   enable_interrupts(INT_RDA);
   #else
   ext_int_edge(H_TO_L);
   output_low(RS485_RX_ENABLE);
// The index for the temporary receive buffer
int8 temp_ni;
// Purpose:    Add a byte of data to the temporary receive buffer
// Inputs:     The byte of data
// Outputs:    None
void rs485_add_to_temp(int8 b) {
   // Store the byte
   rs485_buffer[temp_ni] = b;
   // Make the index cyclic
   if(++temp_ni >= RS485_RX_BUFFER_SIZE)
      temp_ni = 0;
// Purpose:    Interrupt service routine for handling incoming RS485 data
#int_rda
#else
#int_ext
void incomming_rs485() {
   int16 b;
   static int8  cs,state=0,len;
   static int16 to,source;
   [b]static int1 header_find = FALSE;[/b]
   b=fgetc(RS485);
  [b] if (!header_find)
     if (msg_hearder == b)
       header_find = TRUE;
     return;
   }[/b]
   cs^=(int8)b;
   switch(state) {
      case 0:  // Get from address
         temp_ni=rs485_ni;
         source=b;
         cs=b;
         rs485_add_to_temp(source);
      case 1:  // Get to address
         to=b;
         #if (getenv("AUART")&&(RS485_USE_EXT_INT==FALSE))
            setup_uart(UART_DATA);
      case 2:  // Get len
         len=b;
         rs485_add_to_temp(len);
      case 255:   // Get checksum
         if ((!cs)&&(bit_test(to,8))&&(bit_test(source,8))&&((int8)to==RS485_ID))
         {  // If cs==0, then checksum is good
            rs485_ni=temp_ni;
         state=0;
         return;
      default: // Get data
         rs485_add_to_temp(b);
         --len;
   if ((state>=3) && (!len)) {
      state=255;
   else {
      ++state;
// Purpose:    Send a message over the RS485 bus
// Inputs:     1) The destination address
//             2) The number of bytes of data to send
//             3) A pointer to the data to send
// Outputs:    TRUE if successful
//             FALSE if failed
// Note:       Format:  source | destination | data-length | data | checksum
int1 rs485_send_message(int8 to, int8 len, int8* data) {
   int8 try, i, cs;
   int1 ret = FALSE;
   RCV_OFF();
      disable_interrupts(GLOBAL);
   for(try=0; try<5; ++try)
      rs485_collision = 0;
     [b] fputc(msg_hearder, RS485_CD);[/b]
      fputc((int16)0x100|rs485_id, RS485_CD);
      fputc((int16)0x100|to, RS485_CD);
      fputc(len, RS485_CD);
      for(i=0, cs=rs485_id^to^len; i<len; ++i) {
         cs ^= *data;
         fputc(*data, RS485_CD);
         ++data;
      fputc(cs, RS485_CD);
      if(!rs485_collision) {
         ret = TRUE;
      delay_ms(RS485_ID);
   RCV_ON();
   return(ret);
// Purpose:    Wait for wait time for the RS485 bus to become idle
// Inputs:     TRUE - restart the watch dog timer to prevent reset
//             FALSE - watch dog timer not restarted
// Outputs:    None
void rs485_wait_for_bus(int1 clrwdt)
   int16 i;
   RCV_OFF();
   for(i=0; i <= (rs485_wait_time*20); ++i)
      if(!input(RS485_RX_PIN))
         i = 0;
         delay_us(50);
      if(clrwdt)
         restart_wdt();
// Purpose:    Get a message from the RS485 bus and store it in a buffer
// Inputs:     1) A pointer to a buffer to store a message
//             2) TRUE  - wait for a message
//                FALSE - only check if a message is available
// Outputs:    TRUE if a message was received
//             FALSE if wait is FALSE and no message is available
// Note:       Data will be filled in at the pointer as follows:
//             FROM_ID  DATALENGTH  DATA...
int1 rs485_get_message(int* data_ptr, int1 wait)
   while(wait && (rs485_ni == rs485_no)) {}
   if(rs485_ni == rs485_no)
      return FALSE;
   else {
      int n;
      n = rs485_buffer[(rs485_no+1)%sizeof(rs485_buffer)] + 2;
      for(; n>0; --n)
         *data_ptr = rs485_buffer[rs485_no];
         if(++rs485_no >= sizeof(rs485_buffer))
            rs485_no = 0;
         ++data_ptr;
      return TRUE;
Jim
PostPosted: Sat May 27, 2006 11:21 pm     Reply with quote
I tried to highed the code that I added in, but somehow it did not work.
Please look for the variable: "msg_hearder".
Thank
