Directing to an output directory?
tstein
PostPosted: Sat May 27, 2006 10:27 am     Reply with quote
Is there anyway to instruct a compiled project to put output filex (hex, lst, etc) into a specific directory? I'm using CCS from MPLAB directly and can't seem to find anyway to do it.
Thanks,
Tomas
GaryEwer
PostPosted: Thu Jan 21, 2010 7:32 am     Reply with quote
I presume by the lack of response that this is (still?) not possible?
ta,
Gary
PostPosted: Thu Jan 21, 2010 2:33 pm     Reply with quote
If there was an option to control the output location of the .HEX file
it would be listed in this section of the manual, or in the README.TXT:
Invoking the Command Line Compiler
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
The Readme.txt for vs. 4.104 (PCM, PCH) does not list such an option.
mbradley
PostPosted: Thu Jan 21, 2010 5:45 pm     Reply with quote
Give this a try:
// put this atop your main.c file (before including main.h)
#define _BUILD_FILE "myCoolProject"
#define _BUILD_DIR "s:\uControllers\pic\bin"
// put this in your main.h file just under #device line
#define _BUILD_DIR "\" _BUILD_FILE ".hex"
#export (file=_BUILD_FILE, HEX)
Michael Bradley
www.mculabs.com
Open Drivers and Projects
GaryEwer
PostPosted: Mon Jan 25, 2010 2:53 am     Reply with quote
Great - thanks. I'll give it a go.
Gary
