poiuy Guest
RF modules testing |
Posted: Fri May 19, 2006 9:58 pm |
I got an RF module and I suspect it is defective.
I connected the vcc and ground for the transmitter and receiver. Receiver
dataout does not go high when I set the transmitter datain high.
Does this mean the module is broken? I want to do serial communication between a pda and a PIC. |
Posted: Fri May 19, 2006 11:19 pm |
sometimes you can only transmit an AC signal with these modules... try putting a 1khz square wave with TTL level at the input and see it it shows at the output of the other module. |
rberek
Joined: 10 Jan 2005 Posts: 207 Location: Ottawa, Canada
Posted: Sat May 20, 2006 4:52 am |
And some modules only want to see RS232 or other protocols. Read the manual and see what it says. |
poiuy2 Guest
Posted: Sat May 20, 2006 2:53 pm |
I hooked up my pda's tx pin to my transmitter datain and my receiver dataout to my computer. I sent ascii U from my pda but nothing shows up on my computer.
I haven't tried the 1khz signal input b/c I don't have an oscilloscope
I got the RF modules on ebay and have the datasheet for them but there aren't a lot of information on the modules. |
op Guest
Posted: Sat May 20, 2006 2:54 pm |
they are ISM 315mhz modules. |
Posted: Sat May 20, 2006 4:42 pm |
probably they accept 5v ttl levels, not +-12V RS-232 levels. You need a couple of MAX232 or similar chips to put them working. |
Humberto
Posted: Sat May 20, 2006 9:43 pm |
Check if this are your modules:
http://friendcom.en.alibaba.com/product/50144632/50667153/ISM_Micro_Power_Data_RF_Module/ISM_Micro_power_RF_Module.html
Detailed Product Description
FC-201/SR features:
1) Operating in ISM band
2) Compact full-functional module
3) CMOS/TTL compatible output
4) Voltage: 3V
5) Low current consumption: 2.5mA
6) Capture frequency: 433MHz (315MHz also available)
7) Size: 30 x 13mm
FC-201/ST features:
1) Transmitting range up to 100 meters
2) CMOS/TTL input
3) Single supply voltage: 3V
4) Low current consumption: 5mA
5) Low spurious emissions: -30dBC
6) Size: 18 x 18mm
According to this, your modules had been fried.
Humberto |
Guest Guest
Posted: Wed May 24, 2006 1:46 am |
is it possible that the receiver is not tuned? It has a variable capacitor on it.
How do I tune the receiver? I don't have any RF measurement tools btw. |
guest Guest
Posted: Wed May 24, 2006 1:53 am |
I was messing around with the tuning and I found a position on the variable cap that makes the receiver output = 0.4v when the trans input =5 and receiver output= 1.45v when trans input=0.
Kinda wierd how it is inverted and the voltage is not TTL |
Humberto
Posted: Wed May 24, 2006 6:45 am |
The Receiver digital output should swing rail to rail.
It doesn't matter if the output is inverted, you can change the phase with a single transistor + 2 resistors.
Also you can manage an inverted signal wiring the incoming data ( TTL level) directly to the PIC.
Then use a software UART handler, invoking the REVERSE option in the rs232 directive definition
to take care of the reversing signal.
It would be easy if you can borrow a scope to see what's going on.
Humberto |
guest Guest
Posted: Wed May 24, 2006 4:48 pm |
I hooked up the RF receiver to the scope and the output looks good. I transmitted a 1khz squarewave and the receiver got it. The weird thing is that sometime the output is inverted. If I shake or move the transmitter in a certain way, the output of the receiver would invert itself.
Also, when I stop transmitting, the RF receiver outputs some random signals. |
guest Guest
Posted: Thu May 25, 2006 12:00 am |
I use a transistor to amp. the 2.5v to around 3.5V which is enough i think for rs232. So now low=0v and high= 3.5v.
I tried sending UUUUU from my pda and I see it on the screen. The problem i'm having is garbage output. It is outputing a lot of garbage whenever I hook the transmitter Datain to my pda's TX pin. If i don't hook it up, then it is fine (Datain of transmitter is pulled up high) no garbage.
It seems like my pda outputs noise or some sort. I hooked up my pda to my computer directly and serial com works fine without garbage. Wierd.
Any advice? |
Humberto
Posted: Thu May 25, 2006 3:09 pm |
This behaviour is normal in this kind of AM receiver. They have very poor selectivity and
the 315Mhz band is extensivelly used because is a licence free band in USA and other
countries -hence very noisy- (I know that it is not the same for Europa, where is used
specifically for Earth-to-Space satellite uplinks, but Iīm not sure if this is actually true)
This kind of transmitter normally irradiate RF when Datain = HIGH.
You must be aware that it doesnīt matter what you do, you will never get a robust wireless
link using this kind of "toys". There are different techniques to improve this kind of weak
RF links, for example using redundant transmission, that is: you send the packet 3 times,
in the receiver side you stored the packet 3 times and then make a majority comparison.
Also you can use a balanced codified signals, or you can include a CRC result in the payload
to validate the received packet, it depends of your skills and experience with the hardware
and/or the software.
Humberto |
treitmey
Posted: Thu May 25, 2006 3:17 pm |
Humberto: Do you have a suggestion for a more reliable RF module?
Any experience with one brand or another? |
Humberto
Posted: Thu May 25, 2006 4:05 pm |
treitmey,
The limitations of this kind of transmitters that operate in a free band, is that the regulations
itself do not allow that this devices irradiate more RF power.
Anyway Iīm not involved in RF devices, I worked in a project with this kind of devices
(AM transmitters in 315/433Mhz) and tested a few of them but for sure, I do not remember
none of them who have been really superior.
Actually there are a new generation of devices with superb performance (according with
the manufacturer data sheet of course) that I didnīt play with them yet.
Just an example:
Key features of the EZRadio transceiver chipsets include:
"Highly programmable: Choice of unlicensed band (433, 868, 915MHz),
low noise amplifier (LNA) gain, baseband bandwidth (67kHz - 400kHz), data rate, automatic
frequency control, crystal load capacitance, output power level, FSK modulation deviation
- reducing production and customization costs.
Automatic Antenna Tuning (patent pending): Eliminates the need for production line
tuning costs and ensures optimal RF transmission throughout the product lifecycle.
Automatic Antenna Tuning takes the guesswork out of the design process, eliminates the need
for expensive RF engineering, and delivers an extremely robust wireless link.
Fully integrated on-chip RF features: Requires only two external components, a crystal
and a low-cost microcontroller, reducing the bill of materials and simplifying the design-in process.
Automatic Frequency Control (AFC): The receiver is automatically tuned to the incoming signal,
allowing the use of an inexpensive crystal without compromising the radio link.
Key radio management functions: EZRadio performs functions such as data recovery and
timing without a microcontroller, allowing the choice of a less expensive microcontroller.
Clock source available: Does not require a second crystal if a microcontroller is used.
Fast and reliable frequency hopping: Counter interference and multipath fading enable
over a hundred devices to be used in the same environment, without user issues.
High impedance loop antenna can be etched directly onto the circuit board:
Eliminates the need for more expensive external antenna designs. "
I want to state that I have not any kind of relationship nor comercial interest with EZRadio.
regards,
Humberto |
