Error by input_b
pfaerber
Error by input_b
PostPosted: Thu Jan 09, 2003 5:17 am     Reply with quote
Wenn I use this Programm
int idummy;
port_b_pullups(FALSE);
set_tris_b(0xf8);
output_bit(PIN_B0,FALSE);
output_bit(PIN_B1,FALSE);
output_bit(PIN_B2,FALSE);
while (TRUE)
idummy = input_b();
} // while
} // main
all is fine. Wenn I change the port_b_pullups line to True
the outputs switch to high.
Is this OK ??? (why)
___________________________
Original Post ID: 10556
Re: Error by input_b
PostPosted: Thu Jan 09, 2003 12:45 pm     Reply with quote
:=all is fine. Wenn I change the port_b_pullups line to True
:=the outputs switch to high.
:=Is this OK ??? (why)
Make sure your #fuses statement has NOLVP at the end.
See the example below:
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
#use Delay(clock=8000000)
I'm not certain that this will solve your problem,
but I think it's possible.
Original Post ID: 10570
pfaerber
PostPosted: Fri Jan 10, 2003 3:41 am     Reply with quote
:=:=all is fine. Wenn I change the port_b_pullups line to True
:=:=the outputs switch to high.
:=:=Is this OK ??? (why)
:=Make sure your #fuses statement has NOLVP at the end.
:=See the example below:
:=#include <16F877.h>
:=#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
:=#use Delay(clock=8000000)
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
:=I'm not certain that this will solve your problem,
:=but I think it's possible.
I have NOLVP in the config
#include <16F876.h>
#device *=16
#use delay(clock=4000000,RESTART_WDT)
#fuses XT,NOWDT,PUT,BROWNOUT,NOPROTECT,NOLVP
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7)
Original Post ID: 10588
Tomi
PostPosted: Fri Jan 10, 2003 4:16 am     Reply with quote
Yes, because input_x() sets the tris register to input ALL the pins.
If you want to use input_b() but pin0-2 output use this line:
#use FIXED_IO(port_outputs = pin_b0,pin_b1,pin_b2)
After this, the input_b() function sets TRIS_B to 0xF8 instead of 0xFF.
:=Wenn I use this Programm
:=void main()
:= int idummy;
:= port_b_pullups(FALSE);
:= set_tris_b(0xf8);
:= output_bit(PIN_B0,FALSE);
:= output_bit(PIN_B1,FALSE);
:= output_bit(PIN_B2,FALSE);
:= while (TRUE)
:= idummy = input_b();
:= } // while
:=} // main
Original Post ID: 10590
pfaerber
PostPosted: Fri Jan 10, 2003 5:00 am     Reply with quote
I have the NOLVP statement :-(
#include <16F876.h>
#device *=16
Original Post ID: 10591
pfaerber
PostPosted: Fri Jan 10, 2003 5:24 am     Reply with quote
:=Yes, because input_x() sets the tris register to input ALL the pins.
:=If you want to use input_b() but pin0-2 output use this line:
:=#use FIXED_IO(port_outputs = pin_b0,pin_b1,pin_b2)
:=After this, the input_b() function sets TRIS_B to 0xF8 instead of 0xFF.
Yes it works.
the old input
.................... idummy = input_b();
0026: MOVLW FF
0027: BSF 03.5
0028: MOVWF 06
0029: BCF 03.5
002A: MOVF 06,W
002B: MOVWF 21
the new input
0029: MOVLW F8
002A: BSF 03.5
002B: MOVWF 06
002C: BCF 03.5
002D: MOVF 06,W
002E: MOVWF 21
Thank you for your reply. Now it works fine.
Original Post ID: 10592
