String Routine
Pilt1
String Routine
PostPosted: Wed May 24, 2006 3:34 pm     Reply with quote
I wish to pass a string to a function and send each character seperatly
This is my function at the moment
void send_string(char string[10]) //need to use pointers
int8 i;
for(i=0;string[i] != '/n' ;i++)
send(string[i]);
I wish to call the function like this
send_string("Hello");
As you can see i wish to send the first character first and stop after the last character. That why i used the /n character to represent the character after last although i dont think it is correct?
How can i do this?
Pilt
PostPosted: Wed May 24, 2006 3:45 pm     Reply with quote
You can't pass a pointer to a constant string in CCS. You have to
copy the string to a RAM array first, and then pass the address of
the array. Use the CCS function strcpy() to do this.
But maybe you don't need to do that. It seems that you want to
send characters to a special function that will transmit them.
CCS has a special feature of the printf() function, where the output
of printf is sent to a specified function, one character at a time.
In the example program below, the output of printf() is sent to
the send_char() function. (I have renamed your "send_string()"
function to "send_char").
#include <16F877.H>
send(char c)
putc(c);
void send_char(char c)
send(c);
printf(send_char, "Hello");
pilt1
PostPosted: Wed May 24, 2006 3:58 pm     Reply with quote
Yeah sorry was ment to delete the comments regarding pointers.
The reason i am doing it using this method is because i am passing the value to a 8 bit wide port on the uP which connects to another chip (Usb Chip)
The send method places the 8 bit wide data on the port and triggers another ouptut to tell the other chip to accept the data. Therefore to send a string i pass each byte using the send(byte); function.
Pilt
PostPosted: Wed May 24, 2006 4:17 pm     Reply with quote
In that case, the program below will show how to do it.
#include <16F877.H>
#define STROBE PIN_C0
send(char c)
output_d(c);   // Write char to port D
delay_us(1);
output_high(STROBE);   // Create short pulse
delay_us(1);
output_low(STROBE);
printf(send, "Hello");
pilt1
PostPosted: Thu May 25, 2006 12:39 pm     Reply with quote
Thanks that is exactally what i needed!
Cheers
Pilt
