i2c library - help!!
marceleza
PostPosted: Wed May 24, 2006 6:45 pm     Reply with quote
Hi!
I am with one pic 16F877 and a memory 24C04.
I am using the CCS and the library i2c to ready/write the memory.
I change it and I tried to make some changes, I am using the AN10216_1 of the Philips, that deals with i2c - http://www.semiconductors.philips.com/acrobat_download/applicationnotes/AN10216_1.pdf
I tried to make a reading of the memory using the described sequencia in this AN (inside of the document one exists slide number 35), but dont work correct.
I only obtain to make the reading using the code of the CCS. The code of ccs is:
byte read_ext_DEVICE(long int address)
byte data;
i2c_start();
i2c_write(ENDERECO); // 0xA0
i2c_write(address);
i2c_start();
i2c_write(ENDERECO+1);
data=i2c_read(0);
i2c_stop();
return(data);
And my code is:
byte data;
i2c_start();
i2c_write(address);
data=i2c_read(0);
i2c_stop();
return(data);
In the library of ccs I have that to call the address memory (0xA0) + 0, that would be for writing (write) and in sequence a read command.
Somebody can explain pq to me this?
[ ]'s
Marcelo
PostPosted: Wed May 24, 2006 7:42 pm     Reply with quote
Don't use the Philips appnote. Use the actual data sheet for the 24C04.
Here is a link to the data sheet for the Microchip 24LC04B:
http://ww1.microchip.com/downloads/en/DeviceDoc/21708E.pdf
Look at the diagram for "Random Read" on page 10. It matches
the CCS driver code.
Mark
PostPosted: Thu May 25, 2006 7:12 am     Reply with quote
The CCS driver works. Why are you changing it? Did you try it? Remember that you need to have pullups on the clock and data lines.
marceleza
PostPosted: Mon May 29, 2006 5:35 am     Reply with quote
Hi!
Thanks for the aid!
Yes, the code of ccs works fine, I were only curious why in a AN of philips, the way of reading it is deferential of that it is in the example of ccs.
But I saw that the routine that I modified he only serves to read the position of following memory, or either, if I will be in position 00, the reading I will be of position 01.
[]´s
Marcelo
