PIC18F4450 Header File
PetrolDave
PostPosted: Tue May 23, 2006 8:36 am     Reply with quote
I've just purchased v3.236 of the PCH compiler to use on a USB project with the 18F4450 device. But I can't find an 18F4450.h device file?
Do I have to create one by copying the 18F4550.h file and manually editing it? Or is it available from another source.
PostPosted: Tue May 23, 2006 8:54 am     Reply with quote
If you just purchased the compiler, version 3.249 has the .H file you need and you can just download the update from CCS to get all the supported device files. Since the device support is built into the compiler just getting the header file will not solve the problem.
rberek
PostPosted: Tue May 23, 2006 12:00 pm     Reply with quote
This one may be too new to be included yet. I do not have the header file either, and my compiler is up to date. It's datasheet is still marked "Advanced Information" but Microchip indicates it is in production.
I'm guessing it will be there for the next version of the compiler.
PostPosted: Tue May 23, 2006 12:47 pm     Reply with quote
I have PCH vs. 3.249 and I have both those files:
18F4450  H          12,208  03-23-06 12:15p 18F4450.h
18F4550  H          15,580  03-23-06 12:15p 18F4550.h
PostPosted: Tue May 23, 2006 3:56 pm     Reply with quote
My apologies, I guess should have explicitly said I DO have the header files for those versions in 3.249, the same as PCM Programmer
