Runtime Configuration Memory writting- Bootloader
Giorgih
PostPosted: Fri May 19, 2006 3:47 am     Reply with quote
I am developing a CAN bootloader for a P18F448 PIC and I would like to know if there is a command for writting the configuration memory of the PIC (this PIC does allow runtime configuration memory writting).
Than you.
PostPosted: Fri May 19, 2006 4:35 am     Reply with quote
Write_configuration_memory.....
On older compilers (pre perhaps 3.230ish), you just use 'write_program_memory', with tha correct address for the configuration registers. Look in the 'readme' file in your compiler's home directory, and the help file (only updated at about 3.249), to see if your compiler supports this function.
Giorgih
Thank you
PostPosted: Fri May 19, 2006 5:26 am     Reply with quote
In the readme file appears a write_configuration_memory command... I'll check if it works properly in my application.
Than you for your help.
