IM now trying to do the same on a PIC 16f8777a using the CCS compiler
I realize i can do this by using the timer overflow interrupt but is there a way of directly accesing this varible like above?
Pilt
newguy
Posted: Thu May 18, 2006 4:18 pm
Sure - just use a #bit declaration. You need to look in that PIC's datasheet for the exact location of that flag. I did the same thing for a 18F4680, and this is how I did it:
#bit tmr1_int_flag = 0xf9e.0
For the 18F4680, it is bit 0 of memory location 0xF9E. The location of the timer 1 interrupt flag will be different for your processor.
