UART Rx: char missing
EmbdFreak
PostPosted: Tue May 16, 2006 3:14 am     Reply with quote
Hi forum,
A program i had earlier developed has a small UART bug. The system recevies a 3 digit no. followed by CR. It is received this data via a hardware UART. Problem is only two digits are being received correctly.e.g of ABC<CR> being sent, only AB is received leaving out C behind. Can u identify the problematic part?
The following code tested it. Code not relevant to the prob. is not being pasted:
#use rs232 (baud=4800,xmit=PIN_C6,rcv=PIN_C7,stream=SIN_REMOUT,ERRORS)
    output_low(PIN_A0);  // No LCD backlight,until 'A' pressed
    lcd_init();
    rtc_init();
    init_ext_eeprom();
    setup_timer_0(RTCC_INTERNAL| RTCC_8_BIT | RTCC_DIV_256);
    setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
    enable_interrupts(INT_EXT);
    initial_menu();
    fprintf(SIN_REMOUT,"conv\r");  // initializing the modem
    delay_ms(2000);
    lcd_putc('\f');
    lcd_gotoxy(1,1);
    printf(lcd_putc,"*******************");
    lcd_gotoxy(1,2);
    printf(lcd_putc,"Level=");
    set_timer0(0);   //Re-initialize timer here
    INTcountavg=0;   //starts counting NOW !
        fgets(sensorin,SIN_REMOUT); // acquires data
        fprintf(PC,"S%s",sensorin);
        range=strtod(sensorin,endptr); // range in inches stored in long
        snum++;
        if(showrange)
         //   fprintf(PC,"RO");
   displayrange();
   set_timer0(0);   //restart timer0
   set_timer1(0);   //restart timer1
     }   // while ends
EmbdFreak
PostPosted: Tue May 16, 2006 4:01 am     Reply with quote
i think ive figured out the problem. Its the soft uart tx taking more time than the buffer and store char.
Thanks forum !
carmarmu
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Tue May 16, 2006 7:23 am     Reply with quote
Indeed!
You must make the reception of data by interruption, or otherwise, you will lose data.
Luck!!
Thanks forum !
**CaRmArMu** Valencia (Spain)
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue May 16, 2006 7:29 am     Reply with quote
It's a soft UART. Theoretiacally, it's possible to get an interrupt (or rather a "callback") from a soft UART, but does CCS compiler support it?
SLo
PostPosted: Tue May 16, 2006 8:07 am     Reply with quote
If your PIC supports it, you can arrange for the software data Rx pin to be one that also offers an external interrupt and use the external interrupt to trigger the start of software reception.
This still has limitations, but eases the need to frequently call kbhit()
treitmey
PostPosted: Tue May 16, 2006 8:35 am     Reply with quote
Mark
PostPosted: Tue May 16, 2006 12:27 pm     Reply with quote
He's already using the hardware uart for receiving!
SLo
PostPosted: Tue May 16, 2006 3:26 pm     Reply with quote
...and a software serial port?
Mark
PostPosted: Tue May 16, 2006 6:01 pm     Reply with quote
Yes, but this appears to be for debugging. I see no place where the poster is trying to receive from a software uart therefore all these suggestions are pointless.
