Bug in CCS 3.245 for interrupt vectors
pirev
View user's profile Send private message Visit poster's website ICQ Number
PostPosted: Mon May 15, 2006 1:37 pm     Reply with quote
Hi all,
here is piece from my program:
#include <16f913.h>
#CASE
int8    frtcc, catod, Display, i,
      rtcc10ms, rtcc100ms,
       rtcc1s, rtcc1m,
      iTemp;
char const szLedTable=29;
char const LedTable[szLedTable] = {
 0x3F, 0x06, 0x5B, 0x4F,   // characters 0,1,2 & 3
 0x66, 0x6D, 0x7D, 0x07,   // characters 4,5,6 & 7
 0x7F, 0x6F, 0x77, 0x7C,   // characters 8,9,A,B
 0x39, 0x5E, 0x79, 0x71,   // characters C,D,E,F
 0x78, 0x76, 0x73, 0x38,   // characters T,H,P,L
 0x01, 0x41, 0x49, 0x00,   // Upper line,Upper & Middle line, Upper,Middle & Bottom line, NO DIGIT
 0x1C, 0x54, 0x5C, 0x50,   // 'u', 'n', 'o', 'r'
 0x80
int8   DisplayPattern[szLedTable];
// Reserve RAM to save in interrupt vector W,STATUS,PCLATH & FSR registers
#RESERVE 0x7C,0x7D,0x7E,0x7F
#RESERVE 0xFC,0xFD,0xFE,0xFF
#BYTE Wtemp=0x7C
#BYTE STATUStemp=0x7D
#BYTE PCLATHtemp=0x7E
#BYTE FSRtemp=0x7F
inline void PushOntoStack(void)   {
#asm
   movwf    Wtemp       // Store W-reg
   swapf    STATUS,W    // Swap status to be saved into W
   clrf    STATUS       // bank 0, Clears IRP,RP1,RP0
   movwf    STATUStemp    // Save status to bank zero STATUS_TEMP
   movf    PCLATH,W   // pages 1, 2 and/or 3
   movwf    PCLATHtemp   // Save PCLATH into W
   clrf    PCLATH       // Page zero, regardless of current page
   movf    FSR,W       // Copy FSR to W
   movwf    FSRtemp    // Copy FSR from W to FSR_TEMP
#endasm
inline void PopFromStack(void)   {
#asm
   clrf   STATUS      // bank0
   movf   FSRtemp,W   // Restore FSR register
   movwf   FSR
   movf    PCLATHtemp,W    // Restore PCLATH
   movwf    PCLATH       // Move W into PCLATH
   swapf    STATUStemp,W    // Swap STATUS_TEMP register into W
            // (sets bank to original state)
   movwf    STATUS       // Move W into STATUS register
   swapf    Wtemp,F    // Swap W_TEMP
   swapf    Wtemp,W    // Swap W_TEMP into W
   retfie         // end of interrupt vector
#endasm
#INT_GLOBAL
void InterruptHandler(void)      // Global interrupt vector for PIC16
   PushOntoStack();   // Store registers in 'Stack'
   if( T0IF ) {
       TMR0 = 162;
      T0IF = 0;
         Some program code
   PopFromStack();      // Restore registers from 'Stack'
void LoadDisplayPattern(void) {
   i = 0;
   do {
      DisplayPattern[i] = LedTable[i];
   } while( ++i < szLedTable );
void InitHardware(void)   {
   OPTION_REG = 0x84; // 1:32, pull up disable,
   catod = 1;
   LoadDisplayPattern();
    TMR0 = 162;
   T0IF = 0; T0IE = 1;
   INTCON |= 0xC0;   // Enable all unmasked interrupts
void main(void)   {
   InitHardware();
   while( 1 ) {
          Some program code
and here is a piece from listing:
MPASM
CCS PCM C Compiler, Version 3.245, 28193               15-Ìàé-06 22:35
               Filename: C:\myfile\prog\pic\c\ccsc\proba.lst
               ROM used: 109 words (3%)
                         Largest free fragment is 2048
               RAM used: 46 (26%) at main() level
                         47 (27%) worst case
               Stack:    3 worst case (2 in main + 1 for interrupts)
0000 3000       00001 MOVLW  00
0001 008A       00002 MOVWF  0A
0002 2859       00003 GOTO   059
0003 0000       00004 NOP
0000            00005 .................... #include <16f913.h>
0000            00006 .................... //////// Standard Header file for the PIC16F913 device ////////////////
0000            00007 .................... //#device PIC16F913
0000            00008 .................... #device PIC16F913
0004 100A       00009 BCF    0A.0
0005 108A       00010 BCF    0A.1
0006 110A       00011 BCF    0A.2
0007 0782       00012 ADDWF  02,F
0008 343F       00013 RETLW  3F
0009 3406       00014 RETLW  06
000A 345B       00015 RETLW  5B
000B 344F       00016 RETLW  4F
000C 3466       00017 RETLW  66
000D 346D       00018 RETLW  6D
000E 347D       00019 RETLW  7D
000F 3407       00020 RETLW  07
0010 347F       00021 RETLW  7F
0011 346F       00022 RETLW  6F
0012 3477       00023 RETLW  77
0013 347C       00024 RETLW  7C
0014 3439       00025 RETLW  39
0015 345E       00026 RETLW  5E
0016 3479       00027 RETLW  79
0017 3471       00028 RETLW  71
0018 3478       00029 RETLW  78
0019 3476       00030 RETLW  76
001A 3473       00031 RETLW  73
001B 3438       00032 RETLW  38
001C 3401       00033 RETLW  01
001D 3441       00034 RETLW  41
001E 3449       00035 RETLW  49
001F 3400       00036 RETLW  00
0020 341C       00037 RETLW  1C
0021 3454       00038 RETLW  54
0022 345C       00039 RETLW  5C
0023 3450       00040 RETLW  50
0024 3480       00041 RETLW  80
0000            00042 .................... #define __16F913
0000            00724 .................... #list
0000            00725 ....................
0000            00726 .................... #CASE
0000            00727 ....................
0000            00728 .................... int8    frtcc, catod, Display, i,
0000            00729 ....................       rtcc10ms, rtcc100ms,
0000            00730 ....................        rtcc1s, rtcc1m,
0000            00731 ....................       iTemp;
0000            00732 ....................
0000            00733 .................... char const szLedTable=29;
0000            00734 .................... char const LedTable[szLedTable] = {
0000            00735 ....................  0x3F, 0x06, 0x5B, 0x4F,   // characters 0,1,2 & 3
0000            00736 ....................  0x66, 0x6D, 0x7D, 0x07,   // characters 4,5,6 & 7
0000            00737 ....................  0x7F, 0x6F, 0x77, 0x7C,   // characters 8,9,A,B
0000            00738 ....................  0x39, 0x5E, 0x79, 0x71,   // characters C,D,E,F
0000            00739 ....................  0x78, 0x76, 0x73, 0x38,   // characters T,H,P,L
0000            00740 ....................  0x01, 0x41, 0x49, 0x00,   // Upper line,Upper & Middle line, Upper,Middle & Bottom line, NO DIGIT
0000            00741 ....................  0x1C, 0x54, 0x5C, 0x50,   // 'u', 'n', 'o', 'r'
0000            00742 ....................  0x80
0000            00743 .................... };
0000            00744 ....................
0000            00745 .................... int8   DisplayPattern[szLedTable];
0000            00746 ....................
0000            00747 .................... // Reserve RAM to save in interrupt vector W,STATUS,PCLATH & FSR registers
0000            00748 .................... #RESERVE 0x7C,0x7D,0x7E,0x7F
0000            00749 .................... #RESERVE 0xFC,0xFD,0xFE,0xFF
0000            00750 .................... #BYTE Wtemp=0x7C
0000            00751 .................... #BYTE STATUStemp=0x7D
0000            00752 .................... #BYTE PCLATHtemp=0x7E
0000            00753 .................... #BYTE FSRtemp=0x7F
0000            00754 ....................
0000            00755 .................... inline void PushOntoStack(void)   {
0000            00756 .................... #asm
0000            00757 ....................    movwf    Wtemp       // Store W-reg
0025 00FC       00758 MOVWF  7C
0000            00759 ....................    swapf    STATUS,W    // Swap status to be saved into W
0026 0E03       00760 SWAPF  03,W
0000            00761 ....................    clrf    STATUS       // bank 0, Clears IRP,RP1,RP0
0027 0183       00762 CLRF   03
0000            00763 ....................    movwf    STATUStemp    // Save status to bank zero STATUS_TEMP
0028 00FD       00764 MOVWF  7D
0000            00765 ....................    movf    PCLATH,W   // pages 1, 2 and/or 3
0029 080A       00766 MOVF   0A,W
0000            00767 ....................    movwf    PCLATHtemp   // Save PCLATH into W
002A 00FE       00768 MOVWF  7E
0000            00769 ....................    clrf    PCLATH       // Page zero, regardless of current page
002B 018A       00770 CLRF   0A
0000            00771 ....................    movf    FSR,W       // Copy FSR to W
002C 0804       00772 MOVF   04,W
0000            00773 ....................    movwf    FSRtemp    // Copy FSR from W to FSR_TEMP
002D 00FF       00774 MOVWF  7F
0000            00775 .................... #endasm
0000            00776 .................... }
My array LedTable is placed at address 0x0004, where must be placed code for interrupt vector ( I'm using #INT_GLOBAL ), and code for interrupt vector started from address 0x0025. Before version 3.245 I was used 3.241 and there are no problem with #INT_GLOBAL definition and constants in ROM area.
PostPosted: Mon May 15, 2006 3:14 pm     Reply with quote
Add and 'enable_interrupt' in your main. You will then find that the compiler handles the interrupts correctly.
The optimiser sees that the interrupts are never enabled, and does not therefore bother to 'look' for the interrupt keywords. Turning down the optimiser will also fix this.
As a general 'comment', you can just declare the temp registers as integers, and not waste the space declaring them as you do. Alternatively use '#locate', which acts like the combination of a byte, and reserve declaration together. Get rid of the retfie in your 'pop' code, the compiler automatically adds a retfie at the end of the interrupt routine.
pirev
PostPosted: Mon May 15, 2006 4:10 pm     Reply with quote
Thanks Ttelmah,
enable_interrupts(GLOBAL) generate the same code as
INTCON |= 0xC0; in my function InitHardware();
Also I set #OPT 0, but situation are not changed. At address 0x0004 compiler place my array LedTable, but not interrupt vector.
PostPosted: Mon May 15, 2006 4:54 pm     Reply with quote
Your code is not compilable, as posted. It's missing the declarations
for STATUS, PCLATH, TMR0, etc. Also, the pre-processor statements
for "inline" are missing the "#" symbol that should be in front of them.
It looks like the problem is caused by a bug in vs. 3.245, because I
tested it with PCM vs. 3.249 and it works OK.
However, it looks like you can fix the problem with 3.245 by using
an #org statement to move the LedTable to another location in ROM.
Then the compiler puts the #int_global code at address 0x0004.
Add the line shown in bold below:
#org 0x100, 0x12F
0x80
pirev
PostPosted: Mon May 15, 2006 11:30 pm     Reply with quote
Thanks PCM programmer,
STATUS, PCLATH, TMR0 and etc, and declared in modifyed 16913.h:
#device PIC16F913
#define __16F913
#nolist
//////// Program memory: 4096x14  Data RAM: 351  Stack: 8
//////// I/O: 25   Analog Pins: 5
//////// Data EEPROM: 256
//////// C Scratch area: 77   ID Location: 2000
//////// Fuses: LP,XT,HS,EC,NOWDT,WDT,NOPUT,PUT,PROTECT,NOPROTECT,MCLR
//////// Fuses: NOMCLR,CPD,NOCPD,BROWNOUT,BROWNOUT_SW,BROWNOUT_NOSL
//////// Fuses: NOBROWNOUT,IESO,NOIESO,FCMEN,NOFCMEN,DEBUG,NODEBUG,INTRC_IO
//////// Fuses: INTRC,RC_IO,RC
////////////////////////////////////////////////////////////////// I/O
// Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
//                         PORT_B_PULLUPS(), INPUT(),
//                         OUTPUT_LOW(), OUTPUT_HIGH(),
//                         OUTPUT_FLOAT(), OUTPUT_BIT()
// Constants used to identify pins in the above are:
#define PIN_A0  40
#define PIN_A1  41
#define PIN_A2  42
#define PIN_A3  43
#define PIN_A4  44
#define PIN_A5  45
#define PIN_A6  46
#define PIN_A7  47
#define PIN_B0  48
#define PIN_B1  49
#define PIN_B2  50
#define PIN_B3  51
#define PIN_B4  52
#define PIN_B5  53
#define PIN_B6  54
#define PIN_B7  55
#define PIN_C0  56
#define PIN_C1  57
#define PIN_C2  58
#define PIN_C3  59
#define PIN_C4  60
#define PIN_C5  61
#define PIN_C6  62
#define PIN_C7  63
#define PIN_E3  75
////////////////////////////////////////////////////////////////// Useful defines
#define FALSE 0
#define TRUE 1
#define BYTE int
#define BOOLEAN short int
#define getc getch
#define fgetc getch
#define getchar getch
#define putc putchar
#define fputc putchar
#define fgets gets
#define fputs puts
////////////////////////////////////////////////////////////////// Control
// Control Functions:  RESET_CPU(), SLEEP(), RESTART_CAUSE()
// Constants returned from RESTART_CAUSE() are:
#define WDT_FROM_SLEEP  0
#define WDT_TIMEOUT     8
#define MCLR_FROM_SLEEP 16
#define NORMAL_POWER_UP 24
////////////////////////////////////////////////////////////////// Timer 0
// Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER_0(),
//                              SET_TIMER0() or SET_RTCC(),
//                              GET_TIMER0() or GET_RTCC()
// Constants used for SETUP_TIMER_0() are:
#define RTCC_INTERNAL   0
#define RTCC_EXT_L_TO_H 32
#define RTCC_EXT_H_TO_L 48
#define RTCC_DIV_1      8
#define RTCC_DIV_2      0
#define RTCC_DIV_4      1
#define RTCC_DIV_8      2
#define RTCC_DIV_16     3
#define RTCC_DIV_32     4
#define RTCC_DIV_64     5
#define RTCC_DIV_128    6
#define RTCC_DIV_256    7
#define RTCC_8_BIT      0
// Constants used for SETUP_COUNTERS() are the above
// constants for the 1st param and the following for
// the 2nd param:
////////////////////////////////////////////////////////////////// WDT
// Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
//                            RESTART_WDT()
#define WDT_ON          1
#define WDT_OFF         0
#define WDT_DIV_32      0
#define WDT_DIV_64      2
#define WDT_DIV_128     4
#define WDT_DIV_256     6
#define WDT_DIV_512     8
#define WDT_DIV_1024    10
#define WDT_DIV_2048    12
#define WDT_DIV_4096    14
#define WDT_DIV_8192    16
#define WDT_DIV_16394   18
#define WDT_DIV_32768   20
#define WDT_DIV_65536   22
////////////////////////////////////////////////////////////////// Timer 1
// Timer 1 Functions: SETUP_TIMER_1, GET_TIMER1, SET_TIMER1
// Constants used for SETUP_TIMER_1() are:
//      (or (via |) together constants from each group)
#define T1_DISABLED         0
#define T1_INTERNAL         0x85
#define T1_EXTERNAL         0x87
#define T1_EXTERNAL_SYNC    0x83
#define T1_CLK_OUT          8
#define T1_DIV_BY_1         0
#define T1_DIV_BY_2         0x10
#define T1_DIV_BY_4         0x20
#define T1_DIV_BY_8         0x30
////////////////////////////////////////////////////////////////// Timer 2
// Timer 2 Functions: SETUP_TIMER_2, GET_TIMER2, SET_TIMER2
// Constants used for SETUP_TIMER_2() are:
#define T2_DISABLED         0
#define T2_DIV_BY_1         4
#define T2_DIV_BY_4         5
#define T2_DIV_BY_16        6
////////////////////////////////////////////////////////////////// CCP
// CCP Functions: SETUP_CCPx, SET_PWMx_DUTY
// CCP Variables: CCP_x, CCP_x_LOW, CCP_x_HIGH
// Constants used for SETUP_CCPx() are:
#define CCP_OFF                         0
#define CCP_CAPTURE_FE                  4
#define CCP_CAPTURE_RE                  5
#define CCP_CAPTURE_DIV_4               6
#define CCP_CAPTURE_DIV_16              7
#define CCP_COMPARE_SET_ON_MATCH        8
#define CCP_COMPARE_CLR_ON_MATCH        9
#define CCP_COMPARE_INT                 0xA
#define CCP_COMPARE_RESET_TIMER         0xB
#define CCP_PWM                         0xC
#define CCP_PWM_PLUS_1                  0x1c
#define CCP_PWM_PLUS_2                  0x2c
#define CCP_PWM_PLUS_3                  0x3c
long CCP_1;
#byte   CCP_1    =                      0x15
#byte   CCP_1_LOW=                      0x15
#byte   CCP_1_HIGH=                     0x16
////////////////////////////////////////////////////////////////// SPI
// SPI Functions: SETUP_SPI, SPI_WRITE, SPI_READ, SPI_DATA_IN
// Constants used in SETUP_SSP() are:
#define SPI_MASTER       0x20
#define SPI_SLAVE        0x24
#define SPI_L_TO_H       0
#define SPI_H_TO_L       0x10
#define SPI_CLK_DIV_4    0
#define SPI_CLK_DIV_16   1
#define SPI_CLK_DIV_64   2
#define SPI_CLK_T2       3
#define SPI_SS_DISABLED  1
#define SPI_SAMPLE_AT_END 0x8000
#define SPI_XMIT_L_TO_H  0x4000
////////////////////////////////////////////////////////////////// UART
// Constants used in setup_uart() are:
// FALSE - Turn UART off
// TRUE  - Turn UART on
#define UART_ADDRESS           2
#define UART_DATA              4
////////////////////////////////////////////////////////////////// COMP
// Comparator Variables: C1OUT, C2OUT
// Constants used in setup_comparators() are:
#define A0_A3_A1_A3  0xfff04
#define A0_A3_A1_A2_OUT_ON_A4_A5  0xfcf03
#define A0_A3_A1_A3_OUT_ON_A4_A5  0xbcf05
#define NC_NC_NC_NC  0x0ff07
#define A0_A3_A1_A2  0xfff02
#define A0_A3_NC_NC_OUT_ON_A4  0x9ef01
#define A0_VR_A1_VR 0x3ff06
#define A3_VR_A2_VR 0xcff0e
#bit C1OUT = 0x9c.6
#bit C2OUT = 0x9c.7
////////////////////////////////////////////////////////////////// VREF
// Constants used in setup_vref() are:
#define VREF_LOW  0xa0
#define VREF_HIGH 0x80
// Or (with |) the above with a number 0-15
#define VREF_A2   0x40
// Constants used in setup_low_volt_detect() are:
#define LVD_LVDIN   0x1F
#define LVD_45 0x1E
#define LVD_42 0x1D
#define LVD_40 0x1C
#define LVD_38 0x1B
#define LVD_36 0x1A
#define LVD_35 0x19
#define LVD_33 0x18
#define LVD_30 0x17
#define LVD_28 0x16
#define LVD_27 0x15
#define LVD_25 0x14
////////////////////////////////////////////////////////////////// LCD
// LCD Functions: SETUP_LCD, LCD_SYMBOL, LCD_LOAD
// Constants used in setup_lcd() are:
#define LCD_DISABLED  0
#define LCD_STATIC    0x80
#define LCD_MUX12     0x81
#define LCD_MUX13     0x82
#define LCD_MUX14     0x83
#define STOP_ON_SLEEP 0x40
#define USE_TIMER_1   0x04
#define SEG0_4   1
#define SEG5_8   2
#define SEG9_11  4
#define SEG12_15 8
#define SEG16_19 16
#define SEG20_26 32
#define SEG27_28 64
#define SEG29_31 128
#define ALL_LCD_PINS 255
// Constants used in lcd_symbol() are:
#define COM0 0
#define COM1 32
#define COM2 64
#define COM3 96
////////////////////////////////////////////////////////////////// INTERNAL RC
// Constants used in setup_oscillator() are:
#define OSC_31KHZ   0
#define OSC_125KHZ  0x10
#define OSC_250KHZ  0x20
#define OSC_500KHZ  0x30
#define OSC_1MHZ    0x40
#define OSC_2MHZ    0x50
#define OSC_4MHZ    0x60
#define OSC_8MHZ    0x70
// The following may be OR'ed in with the above using |
#define OSC_TIMER1  1
#define OSC_INTRC   2
#define OSC_NORMAL  0
// A second optional parametter may be used with this part to fine
// tune the speed (signed int)
// Result may be (ignore all other bits)
#define OSC_STATE_STABLE 4
////////////////////////////////////////////////////////////////// ADC
// ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
//                SET_ADC_CHANNEL(), READ_ADC()
// Constants used for SETUP_ADC() are:
#define ADC_OFF                0              // ADC Off
#define ADC_CLOCK_DIV_2    0x100
#define ADC_CLOCK_DIV_4     0x40
#define ADC_CLOCK_DIV_8     0x10
#define ADC_CLOCK_DIV_32    0x20
#define ADC_CLOCK_DIV_16    0x50
#define ADC_CLOCK_DIV_64    0x60
#define ADC_CLOCK_INTERNAL  0x30              // Internal 2-6us
// Constants used in SETUP_ADC_PORTS() are:
#define sAN0            1       //| A0
#define sAN1            2       //| A1
#define sAN2            4       //| A2
#define sAN3            8       //| A3
#define sAN4            16      //| A5
#define NO_ANALOGS      0       // None
#define ALL_ANALOG      31      // A0 A1 A2 A3 A5
// One of the following may be OR'ed in with the above using |
#define VSS_VDD               0x0000          // Range 0-Vdd
#define VREF_VREF             0x6000          // Range VrefL-VrefH
#define VSS_VREF              0x2000          // Range 0-VrefH
#define VREF_VDD              0x4000          // Range VrefL-Vdd
// Constants used in READ_ADC() are:
#define ADC_START_AND_READ     7   // This is the default if nothing is specified
#define ADC_START_ONLY         1
#define ADC_READ_ONLY          6
// Interrupt Functions: ENABLE_INTERRUPTS(), DISABLE_INTERRUPTS(),
//                      EXT_INT_EDGE()
// Constants used in EXT_INT_EDGE() are:
#define L_TO_H              0x40
#define H_TO_L                 0
// Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL                    0x0BC0
#define INT_RTCC                  0x0B20
#define INT_RB                    0x0B08
#define INT_EXT                   0x0B10
#define INT_AD                    0x8C40
#define INT_TBE                   0x8C10
#define INT_RDA                   0x8C20
#define INT_TIMER1                0x8C01
#define INT_TIMER2                0x8C02
#define INT_CCP1                  0x8C04
#define INT_SSP                   0x8C08
#define INT_TIMER0                0x0B20
#define INT_EEPROM                0x8C80
#define INT_OSC_FAIL              0x8D80
#define INT_LCD                   0x8D10
#define INT_LOWVOLT               0x8D04
#define INT_COMP                  0x8D20
#define INT_COMP2                 0x8D40
#define INT_RA0                   0x010B08
#define INT_RA1                   0x020B08
#define INT_RA2                   0x040B08
#define INT_RA3                   0x080B08
#define INT_RA4                   0x100B08
#define INT_RA5                   0x200B08
#define INT_RA6                   0x400B08
#define INT_RA7                   0x800B08
#define INT_RB0                   0x010B08
#define INT_RB1                   0x020B08
#define INT_RB2                   0x040B08
#define INT_RB3                   0x080B08
#define INT_RB4                   0x100B08
#define INT_RB5                   0x200B08
#define INT_RB6                   0x400B08
#define INT_RB7                   0x800B08
#list
//----- Interrupt Vectors -------------------------------------------------
//#BYTE  __RESET  = 0x0000
//#BYTE  __INT    = 0x0004
//----- Special Function Registers ----------------------------------------
#BYTE   INDF     = 0x00
#BYTE   TMR0     = 0x01
#BYTE   PCL      = 0x02
#BYTE   STATUS   = 0x03
#BYTE   FSR      = 0x04
#BYTE   PORTA    = 0x05
#BYTE   PORTB    = 0x06
#BYTE   PORTC    = 0x07
#BYTE   PORTE    = 0x09
#BYTE   PCLATH   = 0x0A
#BYTE   INTCON   = 0x0B
#BYTE   PIR1     = 0x0C
#BYTE   PIR2     = 0x0D
#BYTE   TMR1L    = 0x0E
#BYTE   TMR1H    = 0x0F
#BYTE   T1CON    = 0x10
#BYTE   TMR2     = 0x11
#BYTE   T2CON    = 0x12
#BYTE   SSPBUF   = 0x13
#BYTE   SSPCON   = 0x14
#BYTE   CCPR1L   = 0x15
#BYTE   CCPR1H   = 0x16
#BYTE   CCP1CON  = 0x17
#BYTE   RCSTA    = 0x18
#BYTE   TXREG    = 0x19
#BYTE   RCREG    = 0x1A
#BYTE   CCPR2L   = 0x1B
#BYTE   CCPR2H   = 0x1C
#BYTE   CCP2CON  = 0x1D
#BYTE   ADRES    = 0x1E
#BYTE   ADRESH   = 0x1E
#BYTE   ADCON0   = 0x1F
#BYTE   OPTION_REG = 0x81
#BYTE   TRISA    = 0x85
#BYTE   TRISB    = 0x86
#BYTE   TRISC    = 0x87
#BYTE   TRISE    = 0x89
#BYTE   PIE1     = 0x8C
#BYTE   PIE2     = 0x8D
#BYTE   PCON     = 0x8E
#BYTE   OCSCON    = 0x8F
#BYTE   OSCTUNE    = 0x90
#BYTE   ANSEL    = 0x91
#BYTE   PR2      = 0x92
#BYTE   SSPADD   = 0x93
#BYTE   SSPSTAT  = 0x94
#BYTE   WPUB    = 0x95
#BYTE   IOCB    = 0x96
#BYTE   CMCON1    = 0x97
#BYTE   TXSTA    = 0x98
#BYTE   SPBRG    = 0x99
#BYTE   CMCON0    = 0x9C
#BYTE   VRCON    = 0x9D
#BYTE   ADRESL   = 0x9E
#BYTE   ADCON1   = 0x9F
#BYTE   WDTCON    = 0x105
#BYTE   LCDCON    = 0x107
#BYTE   LCDPS    = 0x108
#BYTE   LVDCON    = 0x109
#BYTE   EEDATA   = 0x10C
#BYTE   EEADR    = 0x10D
#BYTE   EEDATH   = 0x10E
#BYTE   EEADRH   = 0x10F
#BYTE   EECON1   = 0x18C
#BYTE   EECON2   = 0x18D
#BYTE   LCDDATA0 = 0x110
#BYTE   LCDDATA1 = 0x111
#BYTE   LCDDATA3 = 0x113
#BYTE   LCDDATA4 = 0x114
#BYTE   LCDDATA6 = 0x116
#BYTE   LCDDATA7 = 0x117
#BYTE   LCDDATA9 = 0x119
#BYTE   LCDDATA10 = 0x11A
#BYTE   LCDSE0    = 0x11C
#BYTE   LCDSE1     = 0x11D
//----- STATUS Bits -------------------------------------------------------
#bit _C=STATUS.0
#bit _DC=STATUS.1
#bit _Z=STATUS.2
#bit _NOT_PD=STATUS.3
#bit _PD_=STATUS.3
#bit _NOT_TO=STATUS.4
#bit _TO_=STATUS.4
#bit _RP0=STATUS.5
#bit _RP1=STATUS.6
#bit _IRP=STATUS.7
//----- PORTA Bits --------------------------------------------------------
//#bit AN0=PORTA.0
#bit AN1=PORTA.1
#bit AN2=PORTA.2
#bit AN3=PORTA.3
#bit T0CKI=PORTA.4
#bit AN4=PORTA.5
#bit SS_=PORTA.5
//----- PORTB Bits --------------------------------------------------------
#bit EINT=PORTB.0
//----- PORTC Bits --------------------------------------------------------
#bit T1CKI=PORTC.0
#bit T1OSO=PORTC.0
#bit T1OSI=PORTC.1
#bit CCP2=PORTC.1
#bit CCP1=PORTC.2
#bit SCK=PORTC.3
#bit SCL=PORTC.3
#bit SDI=PORTC.4
#bit SDA=PORTC.4
#bit SDO=PORTC.5
#bit TX=PORTC.6
#bit CK=PORTC.6
#bit RX=PORTC.7
#bit DT=PORTC.7
//----- INTCON Bits -------------------------------------------------------
#bit RBIF=INTCON.0
#bit INTF=INTCON.1
#bit T0IF=INTCON.2
#bit RBIE=INTCON.3
#bit INTE=INTCON.4
#bit T0IE=INTCON.5
#bit PEIE=INTCON.6
#bit GIE=INTCON.7
//----- PIR1 Bits ---------------------------------------------------------
#bit TMR1IF=PIR1.0
#bit TMR2IF=PIR1.1
#bit CCP1IF=PIR1.2
#bit SSPIF=PIR1.3
#bit TXIF=PIR1.4
#bit RCIF=PIR1.5
#bit ADIF=PIR1.6
#bit PSPIF=PIR1.7
//----- PIR2 Bits ---------------------------------------------------------
#bit CCP2IF=PIR2.0
#bit BCLIF =PIR2.3
#bit EEIF  =PIR2.4
//----- T1CON Bits --------------------------------------------------------
#bit TMR1ON=T1CON.0
#bit TMR1CS=T1CON.1
#bit NOT_T1SYNC=T1CON.2
#bit T1INSYNC=T1CON.2
#bit T1OSCEN=T1CON.3
#bit T1CKPS0=T1CON.4
#bit T1CKPS1=T1CON.5
//----- T2CON Bits --------------------------------------------------------
#bit T2CKPS0=T2CON.0
#bit T2CKPS1=T2CON.1
#bit TMR2ON=T2CON.2
#bit TOUTPS0=T2CON.3
#bit TOUTPS1=T2CON.4
#bit TOUTPS2=T2CON.5
#bit TOUTPS3=T2CON.6
//----- SSPCON Bits -------------------------------------------------------
#bit SSPM0=SSPCON.0
#bit SSPM1=SSPCON.1
#bit SSPM2=SSPCON.2
#bit SSPM3=SSPCON.3
#bit CKP=SSPCON.4
#bit SSPEN=SSPCON.5
#bit SSPOV=SSPCON.6
#bit WCOL=SSPCON.7
//----- CCP1CON Bits ------------------------------------------------------
#bit CCP1M0=CCP1CON.0
#bit CCP1M1=CCP1CON.1
#bit CCP1M2=CCP1CON.2
#bit CCP1M3=CCP1CON.3
#bit CCP1Y=CCP1CON.4
#bit CCP1X=CCP1CON.5
//----- RCSTA Bits --------------------------------------------------------
#bit RCD8=RCSTA.0
#bit RX9D=RCSTA.0
#bit OERR=RCSTA.1
#bit FERR=RCSTA.2
#bit CREN=RCSTA.4
#bit SREN=RCSTA.5
#bit RC89=RCSTA.6
#bit SPEN=RCSTA.7
//----- CCP2CON Bits ------------------------------------------------------
#bit CCP2M0=CCP2CON.0
#bit CCP2M1=CCP2CON.1
#bit CCP2M2=CCP2CON.2
#bit CCP2M3=CCP2CON.3
#bit CCP2Y=CCP2CON.4
#bit CCP2X=CCP2CON.5
//----- ADCON0 Bits -------------------------------------------------------
#bit ADON=ADCON0.0
#bit GO=ADCON0.2
#bit NOT_DONE=ADCON0.2
#bit DONE_=ADCON0.2
#bit CHS0=ADCON0.3
#bit CHS1=ADCON0.4
#bit CHS2=ADCON0.5
#bit ADCS0=ADCON0.6
#bit ADCS1=ADCON0.7
//----- OPTION_REG Bits -------------------------------------------------------
#bit PS0=OPTION_REG.0
#bit PS1=OPTION_REG.1
#bit PS2=OPTION_REG.2
#bit PSA=OPTION_REG.3
#bit T0SE=OPTION_REG.4
#bit RTE=OPTION_REG.4               // For compatibility
#bit T0CS=OPTION_REG.5
#bit RTS=OPTION_REG.5               // For compatibility
#bit INTEDG=OPTION_REG.6
#bit NOT_RBPU=OPTION_REG.7
#bit RBPU_=OPTION_REG.7
//----- PIE1 Bits ---------------------------------------------------------
#bit TMR1IE=PIE1.0
#bit TMR2IE=PIE1.1
#bit CCP1IE=PIE1.2
#bit SSPIE=PIE1.3
#bit TXIE=PIE1.4
#bit RCIE=PIE1.5
#bit ADIE=PIE1.6
#bit PSPIE=PIE1.7
//----- PIE2 Bits ---------------------------------------------------------
#bit CCP2IE=PIE2.0
//----- PCON Bits ---------------------------------------------------------
#bit NOT_POR=PCON.1
#bit POR=PCON.1               // For compatibility
#bit NOT_BOR=PCON.0
#bit BOR=PCON.0
//----- SSPSTAT Bits ------------------------------------------------------
#bit BF=SSPSTAT.0
#bit UA=SSPSTAT.1
#bit R=SSPSTAT.2
#bit R_W=SSPSTAT.2
#bit NOT_W=SSPSTAT.2
#bit W_=SSPSTAT.2
#bit I2C_START=SSPSTAT.3
#bit S=SSPSTAT.3
#bit P=SSPSTAT.4
#bit I2C_STOP=SSPSTAT.4
#bit D=SSPSTAT.5
#bit D_A=SSPSTAT.5
#bit NOT_A=SSPSTAT.5
#bit A_=SSPSTAT.5
#bit CKE=SSPSTAT.6
#bit SMP=SSPSTAT.7
//----- TXSTA Bits ---------------------------------------------------------
#bit TX9D=TXSTA.0
#bit TXD8=TXSTA.0
#bit TRMT=TXSTA.1
#bit BRGH=TXSTA.2
#bit SYNC=TXSTA.4
#bit TXEN=TXSTA.5
#bit TX89=TXSTA.6
#bit CSRC=TXSTA.7
//-----  ADCON1 Bits -------------------------------------------------------
#bit PCFG0=ADCON1.0
#bit PCFG1=ADCON1.1
#bit PCFG2=ADCON1.2
#bit PCFG3=ADCON1.3
#bit ADFM=ADCON1.7
//-----  EECON1 Bits -------------------------------------------------------
#bit RD=EECON1.0
#bit WR=EECON1.1
#bit WREN=EECON1.2
#bit WRERR=EECON1.3
#bit EEPGD=EECON1.7
 * Useful macros for CCS C compiler
 * Written by Svetoslav Pirev, Nov-2000 - Dec-2005
#define _NOP() #asm nop #endasm
#define _CLRWDT() #asm clrwdt #endasm
#define _MOVLW(value) #asm movlw value #endasm
#define _MOVWF(reg) #asm movwf reg #endasm
#define _ANDLW(value) #asm andlw value #endasm
#define _IORLW(value) #asm iorlw value #endasm
#define _RLF_F(data) #asm rlf data,F #endasm
#define _RLF_W(data) #asm rlf data,W #endasm
#define _RRF_F(data) #asm rrf data,F #endasm
#define _RRF_W(data) #asm rrf data,W #endasm
#define _COMF_F(data) #asm comf data,F #endasm
#define _COMF_W(data) #asm comf data,W #endasm
#define _HIGH(reg) #asm movf reg,W #endasm
#define _MOVF_W(reg) #asm movf reg,W #endasm
#define _MOVF_F(reg) #asm movf reg,F #endasm
#define _ADDWF_F(reg) #asm addwf reg,F #endasm
#define _ADDWF_W(reg) #asm addwf reg,W #endasm
#define _ANDWF_F(reg) #asm andwf reg,F #endasm
#define _ANDWF_W(reg) #asm andwf reg,W #endasm
#define _IORWF_F(reg) #asm iorwf reg,F #endasm
#define _IORWF_W(reg) #asm iorwf reg,W #endasm
#define _SWAPF_F(reg) #asm swapf reg,F #endasm
#define _SWAPF_W(reg) #asm swapf reg,W #endasm
#define _GETFSRF(reg) #asm movf INDF,W    movwf reg   #endasm
#define _SUBWF_W(reg) #asm subwf reg,W #endasm
#define _SUBWF_F(reg) #asm subwf reg,F #endasm
#define _DECF_F(reg) #asm decf reg,F #endasm
#define _DECF_W(reg) #asm decf reg,W #endasm
#define _INCF_F(reg) #asm incf reg,F #endasm
#define _INCF_W(reg) #asm incf reg,W #endasm
#list
#org 0x100, 0x12F
0x80
I will test above code, and it is work fine !
Thanks again.
