rand()
teekaytk
rand()
PostPosted: Thu May 11, 2006 4:17 am     Reply with quote
hi all
i want to generate a random number betwwen 0 and 3, how can i use rand() to generate this number, please help
thanks
TK
Mark
PostPosted: Thu May 11, 2006 6:14 am     Reply with quote
Check the help file. It shows the usage as well as the srand() function.
#define RAND_MAX 3
num = rand();
teekaytk
PostPosted: Thu May 11, 2006 6:20 am     Reply with quote
thanks, it works
Daniel T.
How should I set the seed?
PostPosted: Fri May 12, 2006 7:31 pm     Reply with quote
How should I go about setting the SEED?
PostPosted: Fri May 12, 2006 7:39 pm     Reply with quote
In the CCS manual...srand()
Daniel T.
PostPosted: Fri May 12, 2006 8:42 pm     Reply with quote
But if I hard code a value for the seed, the sequence will be the same each time the pic is powered on, correct?
Daniel T.
Random seeds for srand()
PostPosted: Fri May 12, 2006 9:56 pm     Reply with quote
I think I'm going to use a trick PCs use. Most/some OSes read the RTC from hardware during boottime, and write that data back to hardware at shutdown. I'm going to store a seed number in eeprom. On power up this seed will be read from eeprom. The seed will be used, and every so often a new, randomly generated, seed will be stored back into eeprom. The new seed will be stored after human triggered events, giving truly random seeds for next time the pic is powered on.
