kda406
Joined: 17 Sep 2003 Posts: 97 Location: Atlanta, GA, USA
Bootloader woes / Invalid ORG range |
Posted: Fri May 12, 2006 9:02 am |
I am getting an “Invalid ORG range” error during compile when I believe I should not be. I am using a PIC18F8722 and compiler 3.249.
For reference, the code I am posting here is loosely based on code posted by “ckielstra” and originates from http://www.ccsinfo.com/forum/viewtopic.php?p=62993.
The application program complies correctly, and puts its interrupts in the correct place. It is the bootloader that has the ORG errors.
Com-Atlanta-Bootloader.h:
Code: | ////////////////////////////////////////////////////////////////////////////////
// Some defines for the bootloader: //
// Include this file from the bootloader with ATL_BOOTLOADER defined. //
// Include this file from the application with ATL_BOOTLOADER not defined. //
#define RESET_VECTOR 0x0000 // Defined by hardware
#define HIGH_INT_VECTOR 0x0008 // Defined by hardware
#define NORMAL_INT_VECTOR 0x0018 // Defined by hardware
#define INTERRUPT_END 0x00a3 // End of the interrupt area
#define LOADER_START INTERRUPT_END + 1
#define LOADER_END 0x01FFE // Reserve 8K for the big bootloader
#define LOADER_RESET RESET_VECTOR
#define LOADER_HIGH_INT LOADER_START
#define LOADER_NORMAL_INT LOADER_START + 0x10
#define APPLICATION_START LOADER_END + 2
#define APPLICATION_RESET APPLICATION_START + RESET_VECTOR
#define APPLICATION_HIGH_INT APPLICATION_START + HIGH_INT_VECTOR
#define APPLICATION_NORMAL_INT APPLICATION_START + NORMAL_INT_VECTOR
#ifdef ATL_BOOTLOADER
#build(reset=LOADER_RESET, interrupt=LOADER_HIGH_INT) // Move the reset and interrupt vectors
#else
#build(reset=APPLICATION_RESET, interrupt=APPLICATION_HIGH_INT) // Move the reset and interrupt vectors
#org 0, LOADER_END {} // Reserve the bootlader memory area
#endif
// Below is a global flag byte, indicating if the bootloader is active or not. This flag must be present
// in both the bootloader and the application at the same RAM address, hence we place it here with a #locate
// to lock its address for both programs.
unsigned int8 giBootloaderActive;
//#locate giBootloaderActive=0xF5F <== this won't work because the ISR can't use bank 15; it can only use bank 0
#locate giBootloaderActive=0x0FF
// 05/11/06 - Kyle chose 0xFF because it is the highest ram location in bank 0 of the 18F8722. The ISR
// relocator cannot change ram banks, so the giBootloaderActive flag must exist in bank 0. The CCS compiler
// uses a variable number of @scratch locations (see sym file) and program variable cannot interfere with the
// scratch locations. If one #locate's a RAM variable where the scratch needs to be, then the compiler will
// refuse to compile the program. If we have a bootloader which uses a location that the application requires
// for scratch, then they will become incompatible. Therefore, Kyle left the maximum amount of room for the
// scratch area to grow, still process the ISRs, and satisfy both programs' memory models. |
Test-Bootloader.c:
Code: | #include "18F8722.h"
#fuses HS,NOWDT,NOLVP,PUT,BROWNOUT
#define ATL_BOOTLOADER
#include "Com-Atlanta-Bootloader.h"
#define SYSTEMCLOCK 11059200 //11.0592 MHz Oscillator
// Relocate the interrupt vectors. Depending on whether the bootloader or //
// application is active different interrupt dispatchers are called. //
#org HIGH_INT_VECTOR, INTERRUPT_END
void isr_relocate(void) {
#asm
// Address 0x0008 is the hardware High priority interrupt
TSTFSZ giBootloaderActive // if bootloader active
GOTO LOADER_HIGH_INT // then jump to bootloader ISR
GOTO APPLICATION_HIGH_INT // else jump to application ISR
NOP // Just filling memory
NOP
NOP
// Address 0x0018 is the hardware Low priority interrupt
GOTO LOADER_NORMAL_INT // then jump to bootloader ISR
GOTO APPLICATION_NORMAL_INT // else jump to application ISR
#endasm
#org LOADER_START, LOADER_END default
#int_timer0
void timer0_isr(void) { output_toggle(PIN_J2); }
void main() {
int16 TMR0Period = SYSTEMCLOCK/4/16/80;
giBootloaderActive = TRUE;
set_timer0(TMR0Period);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_4);
// Do your bootloader things here
while(1) {
output_toggle(PIN_J0);
// Exit the bootloader and go to the Real Application
goto_address(APPLICATION_START);
Which produces the following compiler output:
Quote: | Executing: "C:\Program files\Picc\CCSC.exe" "Test-Bootloader.c" +FH +DF +LN +T +A +M +Z +Y=9 +P01 +EA I="S:\Devel\Pic-C\Lib;C:\Program Files\PICC\Devices;C:\Program Files\PICC\Drivers"
>>> Warning 203 "S:\Devel\Pic-C\Proj\Experimental\Test-Bootloader\Test-Bootloader.c" Line 44(1,1): Condition always TRUE
--- Info 300 "S:\Devel\Pic-C\Proj\Experimental\Test-Bootloader\Test-Bootloader.c" Line 53(0,1): More info: Segment at 00000-00006 (0004 used) Priv
--- Info 300 "S:\Devel\Pic-C\Proj\Experimental\Test-Bootloader\Test-Bootloader.c" Line 53(0,1): More info: Segment at 00008-000A2 (0000 used) Priv
--- Info 300 "S:\Devel\Pic-C\Proj\Experimental\Test-Bootloader\Test-Bootloader.c" Line 53(0,1): More info: Segment at 000A4-01FFE (0000 used) Priv
--- Info 300 "S:\Devel\Pic-C\Proj\Experimental\Test-Bootloader\Test-Bootloader.c" Line 53(0,1): More info: Segment at 02000-0FFFE (0000 used)
--- Info 300 "S:\Devel\Pic-C\Proj\Experimental\Test-Bootloader\Test-Bootloader.c" Line 53(0,1): More info: Segment at 10000-1FFFE (0000 used)
--- Info 300 "S:\Devel\Pic-C\Proj\Experimental\Test-Bootloader\Test-Bootloader.c" Line 53(0,1): More info: Attempted to create: 000A4-0013E for ISR
*** Error 126 "S:\Devel\Pic-C\Proj\Experimental\Test-Bootloader\Test-Bootloader.c" Line 53(0,1): Invalid ORG range
1 Errors, 1 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Fri May 12 10:27:48 2006 |
I tried changing the #build command to put the interrupt at several different locations inside the bootloader area. No matter where I put the interrupts, I got this error. Then I noticed that it shows the segment I am using (A4-1FFE) as “Priv”. Yes, it's private, because it was reserved for this function! Just out of curiousity (desperation), I moved the interrupts outside of the bootloader area and it worked!!!
I found that when I move the interrupts for the bootloader into the application code's space, that the program compiles and works. For instance like this:
Code: | #build(reset=LOADER_RESET, interrupt=0x2000) // Move the reset and interrupt vectors |
But, obviously, it is unacceptable to put the remapped interrupt vectors outside the area we have allocated for them!
As far as I can tell from all the research I've done, I'm supposed to #ORG the area I want to keep my bootloader in, remap the interrupt vectors, use #BUILD to put in remapped interrupt vectors in the #ORG I have defined, but located after the vector re-mapper. When I do this, it does not work. PLEASE tell me what I'm doing wrong!
-Kyle |
Posted: Mon May 15, 2006 4:48 pm |
It seems like my example code isn't flexible enough.
A quick-and-dirty fix is to remove the next line from Test-Bootloader.c Code: | #org LOADER_START, LOADER_END default |
and restore Code: | #define INTERRUPT_END 0x00a3 // End of the interrupt area | to 0x0023
Disadvantage is that you don't have section overflow checking when implementing it like this. I'll look into a better solution but don't have time for the next couple of days. |
kda406
Posted: Tue May 23, 2006 8:00 am |
I agree that taking the #org out allows the program to compile. We "get lucky" and the program ends up in the space between LOADER_START and LOADER_END. It seems to me like the #org should work and should be in the code.
-Kyle |
