IAR to CCS
bjerkely12
IAR to CCS
PostPosted: Tue May 09, 2006 1:27 pm     Reply with quote
Hi friends,
I'm trying to convert some IAR code to CCS and have confusions with data declarations.For example what can I use in CCS for
__eeprom __no_init <identifier> ;
Thanx in advance,
treitmey
PostPosted: Tue May 09, 2006 2:19 pm     Reply with quote
What does __eeprom __no_init do?
PostPosted: Tue May 09, 2006 2:46 pm     Reply with quote
See page 14 in this IAR reference guide:
http://www.ee.oulu.fi/~terva/Embedded2003/pdf/cavr.pdf
(The official IAR download page at http://www.iar.com/ is too slow)
Use the CCS typemod directive to do this. In the March 2006
CCS manual, see page 87 (in the Acrobat reader) for an example.
Download the CCS manual from this page:
http://www.ccsinfo.com/downloads.php
bjerkely12
PostPosted: Wed May 10, 2006 5:18 pm     Reply with quote
In CCS manual it says that pointer to constand is not allowed ,ok but how can I handle this
const char *str;
PostPosted: Wed May 10, 2006 5:31 pm     Reply with quote
You could have a global array in RAM, and copy a string into it
by using the CCS strcpy() function and then pass the address
of the RAM array to your function. Example:
#include <16F877.H>
#device *=16
char const msg1[]= {"Hello World"};
char const msg2[]= {"ABCD"};
char const msg3[]= {"Last message"};
char string_buffer[96];
void display_message(char *ptr)
printf("%s\n\r", ptr);
strcpy(string_buffer, msg1);
display_message(string_buffer);
strcpy(string_buffer, msg2);
strcpy(string_buffer, msg3);
Also see this post which uses the switch-case method to work around
the problem of no pointers to constant strings:
http://www.ccsinfo.com/forum/viewtopic.php?t=25483&start=7
