Software I2C
thomas
Software I2C
PostPosted: Tue Jul 15, 2003 1:02 pm     Reply with quote
I know the PIC only has one hardware I2C port. If I use software I2C, can I have more than one I2C ports on a single micro? Thanks!
Thomas
___________________________
Original Post ID: 144516011
jds-pic
Re: Software I2C
PostPosted: Tue Jul 15, 2003 1:25 pm     Reply with quote
yes, you can use multiple i2c, one could be hardware and the rest software-synthesized. however, you have to explicitly code your functions using the #use i2c directives. there is no runtime selection of which i2c port to use.
so you MUST code as follows:
#use i2c(config 1)
my_function_1() {
i2c_start();
#use i2c(config 2)
my_function_2() {
i2c_start();
you MUST NOT code as follows:
if (someval=TRUE) {
#use i2c(config 1)
i2c_start();
else {
#use i2c(config 2)
i2c_start();
good luck,
jim aka jds-pic
:=Hi,
:=I know the PIC only has one hardware I2C port. If I use software I2C, can I have more than one I2C ports on a single micro? Thanks!
:=Thomas
Original Post ID: 144516012
thomas
Re: Software I2C
PostPosted: Tue Jul 15, 2003 1:49 pm     Reply with quote
Thank you very much for your help!
Best wishes and regards,
Thomas
:=yes, you can use multiple i2c, one could be hardware and the rest software-synthesized. however, you have to explicitly code your functions using the #use i2c directives. there is no runtime selection of which i2c port to use.
:=so you MUST code as follows:
:=#use i2c(config 1)
:=my_function_1() {
:=i2c_start();
:=#use i2c(config 2)
:=my_function_2() {
:=i2c_start();
:=you MUST NOT code as follows:
:=if (someval=TRUE) {
:= #use i2c(config 1)
:= i2c_start();
:=else {
:= #use i2c(config 2)
:= i2c_start();
:=good luck,
:=jim aka jds-pic
:=:=Hi,
:=:=I know the PIC only has one hardware I2C port. If I use software I2C, can I have more than one I2C ports on a single micro? Thanks!
:=:=Thomas
Original Post ID: 144516013
Mark
Re: Software I2C
PostPosted: Tue Jul 15, 2003 4:40 pm     Reply with quote
FYI:
In case you didn't know this, multiple i2c devices can be on the same bus.
Regards
Mark
:=Hi,
:=Thomas
Original Post ID: 144516016
