Greetings,
I've just recently started to use ccsc. I've stumbled my way through setting up most everything i want. (reading this forum for help )
I'm using an 16f876 to control an H-Bridge and controling speed via PWM with the Duty controled via analog ala EX_PWM.C.
I would like to scale the output of the analog reading to match the responce of the motor to allow for a greater degree of control. I've developed a plan of attack but seem to be smashing the data during the scaling maths.
Here is the code.
if (input (PIN_C4)) {
value=read_adc();
delay_ms(1);
value = value*38;
value = value/256;
set_pwm1_duty(value + 175);
rtfwd();
My intention is to scale the 0 - 255 from the dac to values between 216 - 242. I've seperated the maths to improve clarity.
Any comments / help / intuition would be appreciated.
e.w.
rberek
Joined: 10 Jan 2005 Posts: 207 Location: Ottawa, Canada
Posted: Sat May 06, 2006 9:00 pm
Is value defined as an int16?
Picster
Posted: Sat May 06, 2006 9:10 pm
Nope it was not. That seemed to take care of it.....now i just need to tweak the values more.
