edpgc Guest
SPI Problem (writing to a ROM) |
Posted: Tue May 02, 2006 3:22 pm |
Hi all
My first post, and my first go at using CCS, so if I get something wrong
or am not posting enough info, please don't bite my head
off!
I'm using CCS C (v3.239) compiler with a PIC16F690
programming with the PicKit2.
http://ww1.microchip.com/downloads/en/DeviceDoc/41262A.pdf
I'm trying to get my PIC to program the ROM in a PCM2705
http://focus.ti.com/lit/ds/symlink/pcm2705.pdf (page
23-25)
I have the PCM2705 hooked up to the hardware SPI Port
directly, and SPI select connected directly to PortC3
The porogram process is a simple matter of downloading
a Product ID, Vendor ID, Device Name string etc.
The issue is that no matter how I try it I either get
the default strings, or scrambled nonsense.
Interestingly I can send single commands to the
PCM2705 such as volume up.
I have had difficulty interrpretting the datasheet, so
I might be going about the ROM writing process the
wrong way.
Here's my sources
============ Main ======================
#include "C:\Documents and Settings\Ed\MyDocuments\DivaProgrammer\version1b.h"
#use delay(clock=1000000)
#DEFINE SSPCON 0x14
#DEFINE ADDR_HIGH 2
#DEFINE ST_HIGH 8
#BIT CKP=SSPCON.4
int8 const ROM_DATA[57] = {0xf3, 0x18, 0x10, 0x00,'T', 'h', 'i', 's', ' ', 'i', 's', 'a', ' ', 'T', 'e', 's', 't', ' ', ' ', ' ', 'V', 'e', 'n','d','o','r',' ','S','t','a','r','t','s',' ','H','e','r','e',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ', 0xc0, 0x0a, 0x0a, 0x93, 0x01};
int8 count;
setup_oscillator(OSC_INTRC);
setup_oscillator(OSC_1MHZ);
setup_adc(ADC_OFF);
output_high(SELECT); // Set select pin high
output_high(PIN_C7);
output_high(PIN_B6);
CKP=1;
setup_spi(SPI_MASTER | SPI_CLK_DIV_64 | SPI_H_TO_L); //Data on High to low!?
CKP=1;
setup_timer_1(T1_DISABLED);
setup_vref(FALSE|0);
delay_ms(100); // Let everything Settle
WHILE(1){
while(input(PIN_A3))
output_toggle(PIN_C0); //FLASH LED
delay_ms(200);
while(!input(PIN_A3)); // until button is pressed, and released
output_low(SELECT); // Set select pin low
delay_us(50);
spi_write(ADDR_HIGH); // Send ADDR command
spi_write(0x00);
delay_us(50);
output_high(SELECT); // Set select pin low
delay_us(500);
count=0;
while(count < 57) // 57 bytes (456bits) to be written
delay_us(50);
spi_write(ST_HIGH); // WIth ST bit set
spi_write(ROM_DATA[count]); // Send ROM data
output_toggle(PIN_C1); // Strobe LED while writing
count++;
delay_us(50);
delay_ms(100); // should be done
============ Header File ===================
#include <16F690.h>
#device adc=8
#FUSES INTRC_IO //Internal RC Osc, noCLKOUT
#FUSES NOPROTECT //Code not protectedfrom reading
#FUSES NOBROWNOUT //
#FUSES NOMCLR //Master Clear
#FUSES NOIESO //Internal ExternalSwitch Over mode disabled
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#define BUTTON PIN_A3
#define LED1 PIN_C0
#define LED2 PIN_C1
#define LED3 PIN_C2
#define SELECT PIN_C3
//#define SPI_CLK PIN_B6
//#define SPI_SDO PIN_C7
Anything obvious?
Thanks!
Ed |
Posted: Wed May 03, 2006 2:12 pm |
There are several things wrong with your code.
1. You have two setup_oscillator() statements. That's wrong.
There should only be one.
2. You have several "magic" pin numbers, that you use in pin i/o
statements. You should refer to the pins by their named constants
that you have in your Version1b.h file.
3. I think you're using the wrong SPI mode.
On page 24 of the PCM2705 data sheet, it shows the SPI write timing.
Go this page, and scroll down near the bottom.
http://www.totalphase.com/support/articles/article03/
It shows a diagram of the clock to data phase relationships for each
SPI mode.
In the Acrobat reader, zoom in on the left side of the timing diagram
for "Single Write Operation" in the PCM2705 data sheet. Notice the idle
state of the clock is a high level. So that means you're going to be in
either Mode 2 or 3, according to the Total Phase website diagram.
Now look closely at the clock to data relationship in the data sheet.
The data changes on the falling edge of clock and is sampled in the
middle of the data cell by the rising edge of clock. So on the Total Phase
website, that's Mode 3.
Now set the SPI mode, according the method shown in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=26888
Code: | setup_spi(SPI_MASTER | SPI_MODE_1_1 | SPI_CLK_DIV_64); |
Get rid of all the manual "CKP = 1" code. Just use the line above. |
edpgc Guest
Posted: Wed May 03, 2006 7:57 pm |
Cheers PCM! I'll look into this tomorrow, I've had a hard time interpreting the TI documentation, to be honest i"m not totally sure of the sequence of the write process.
I'm used to jsut coding in good old assembly, so I wasn't really sure if CCS was setting the CKP bit, got a bit carried away there.
I'll let you know how I get on.
Ed |
