babaracus
40 MHz ceramic oscillator with 18F8722 |
Posted: Tue May 02, 2006 4:39 pm |
hello all,
made own board with PIC18F8722 and am using
a 40 MHz ceramic oscillator (w/ caps) (part no. PX400CCT in DigiKey). this oscillator has been used before in other projects.
listing of header :
include <18f8722.h>
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT,NOPUT,NOPROTECT
#use delay (clock=40000000)
#use rs232 (baud=2400, xmit=PIN_G1, rcv=PIN_G2, stream=PORT1)
#define PINC2trial PIN_C2
i put a 10x scope on OSC2 and get a dc value of 5v and
the scope on OSC1 is a little above common. i'm should see 40MHz
oscillation but obviously don't.
program bumps a pin hi and then low for test purposes:
#include <proto_icd.h>
#include <stdlib.h>
while(TRUE) {
output_high(PINC2trial);
delay_cycles(100);
output_low(PINC2trial);
delay_cycles(100);
of course the pin doesn't move.
any ideas? thanks a bunch.
ba |
Posted: Tue May 02, 2006 4:53 pm |
Look in the 18F8722 data sheet, in the section on Electrical Characteristics.
Find the Table called "External Clock Timing Requirements".
It shows that for HS mode, the maximum frequency is 25 MHz.
If you want to use 40 MHz, according to the table, you have two choices:
1. You can use an external oscillator, in EC mode at 5v.
It looks like Digikey p/n XC323CT would work. Here's a photo:
http://rocky.digikey.com/WebLib/ECS/Web%20Photos/ECS-395-M-EXT.jpg
I picked a surface mount oscillator since your other part number
was also smt.
2. You can use a 10 MHz crystal in H4 mode at 5v.
It looks like Digikey p/n XC716CT would work. Here's a photo:
http://rocky.digikey.com/WebLib/ECS/Web%20Photos/CSM-7%20CRYSTAL.jpg |
jnx
Posted: Sun Oct 22, 2006 12:56 am |
HI PCM programmer / Mark,
IM USING A PIC18F8720 / PIC18F8722 FOR A MONTH.
- I USE 40MHZ ( SG513PH ) WITH FUSE SETTING SHOWN BELOW
I MAKE MY PROTO HARDWARE WORKING PERFECTLY BUT I HAVE QUESTION IN MY MIND:
- DID I OVERCLOCK THE 18F8720 / 18F8722?
- DID I USE THE CORRECT FUSE SETTINGS?
- DID MY OBJECTIVE SATISFY TO USE 40MHZ CRYSTALL TO 18F8720 AND 18F8722?
- RDA IS WORKING GOOD , ANY MAJOR ISSUE WITH RESPECT TO OTHER PERIPHERALS?
#if defined(__PCH__)
#include <18F8720.h>
#device ADC=10
#device *=16
#fuses EC,NOWDT,NOPROTECT,NOLVP,NOPUT
#use delay(clock=40000000)
#use rs232(baud=38400, xmit=PIN_C6, rcv=PIN_C7,ERRORS,STREAM=RS232)
THANX FOR HELPING SMALL GUY LIKE ME, _________________ micro_small,
.NET_PIC'er |
Posted: Sun Oct 22, 2006 2:36 am |
Typing 'ALL IN CAPS', is considered shouting, and rude.
The point being made by PCM programmer, is that what you are doing, is 'out of spec' for the chip. It may well work (people have successfully 'overclocked' many of the PICs), _but_ it is a sure way to build a product that is likely to be unreliable in the future.
So, the answers to your questions, are that:
1) You are overclocking the _oscillator_ section of the chip.
2) No. Since you are doing something that the chip is not designed to do.
3) No. Same comment.
4) The 'core' of the chip, will work happily at this frequency, but the oscillator is likely to become unreliable at temperature/voltage extremes. It is _never_ the way to design a relaible product, to exceed the manufacturers spec.
jnx
Posted: Sun Oct 22, 2006 3:24 am |
Hi Ttelmah,
Many thanx for the feed back and for the CAPS LOCK reminder. Ttelmah now im using 10Mhz oscillator is my fuse settings correct to achive 40mhz in PIC18F8720 / PIC18f8722?
#device ADC=10
#device *=16
#fuses H4,NOWDT,NOPROTECT,NOLVP,NOPUT
#endif _________________ micro_small,
.NET_PIC'er |
Posted: Sun Oct 22, 2006 5:25 am |
Much better. :-)
You don't actually 'need' the #device *=16 line (PIC18 chips always run as if this is used). However having it doesn't cause a problem.
