CODE CONVERSION FROM asm TO CCS C !
deltatech
PostPosted: Mon May 01, 2006 3:23 pm     Reply with quote
Hi i am a new to CCS C i have bought a PICDEM Mechatronics Board its come with this lab example in ASM. Can you experts convert it to CCS C code so that i can understand it and try it out in C many thanks for your help .
   include <p16f917.inc>
   include LCD.inc
STARTUP code
   goto   Start
PORT1    code
Start
   bsf      STATUS,RP0      ; we'll set up the bank 1 Special Function Registers first
   bcf      TRISD,2         ; set RD2 as the motor output
   movlw   b'01110000'      ; select the 8Mhz internal oscillator
   movwf   OSCCON
   movlw   0xFF         ; select 7.9 kHz PWM
   movwf   PR2
   bcf      STATUS,RP0
   movlw   b'00001100'      ; pwm mode
   movwf   CCP2CON
   bsf    T2CON,TMR2ON   ; turn on PWM
   call   InitLCD         ; Initialize the LCD module
   clrf   CCPR2L         ; Clear Duty Cycle
   bsf    ADCON0,ADON    ; Turn the ADC module on
LoopOuter
   bsf      ADCON0,GO_DONE
LoopInner
   btfsc   ADCON0,GO_DONE
   goto   LoopInner
   movf   ADRESH,w
   call   DisplayDecimal   ; Display the ADC value
   movf   ADRESH,w
;   movwf   CCPR2L         ; make POT1 reading the duty cycle
   call   QuietPWM
   goto   LoopOuter
   END
PostPosted: Tue May 02, 2006 12:51 am     Reply with quote
You ought to convert it, in order to learn how to use the compiler
and how to read the .LST file. It's an important skill.
It looks like they're doing something similar to the CCS example file,
EX_PWM.C. You can find this file in: c:\Program Files\PICC\Examples
You'll also need to specify the INTRC_IO fuse, and use the
setup_oscillator() function. See this post for an example:
http://www.ccsinfo.com/forum/viewtopic.php?t=26898
The CCS manual explains the CCS library functions.
