Rs232 & hyperterminal
janiga
PostPosted: Mon May 01, 2006 5:01 pm     Reply with quote
Hello
How can i see the printf"hello" on my pc. I have connected an interface but i am not sure what the settings ought to be in hyperterminal. I can see the data on pin c6 with my scope but nothing shows on my pc. can anyone shed some light on this interface.
#include <16F917.h>
#fuses INTRC_IO, NOWDT, NOPROTECT
#use delay (clock = 8000000)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
setup_oscillator(OSC_8MHZ);
   output_high(PIN_A0);
   output_low(PIN_A0);
   printf("Hello");
PostPosted: Tue May 02, 2006 12:24 am     Reply with quote
Here is a post that describes how to setup Hyperterminal:
http://www.ccsinfo.com/forum/viewtopic.php?t=9253&start=1
Here is the CCS FAQ article on RS-232 problems:
http://www.ccsinfo.com/faq.php?4
Here is a schematic of a MAX232 circuit:
http://web.ukonline.co.uk/j.winpenny/pic/rs232x.gif
Note that if you're using a MAX232A, then you should use 0.1 uF
capacitors, instead of the 1 uF caps.
