Problems with F Bus Please
manu8888
PostPosted: Mon May 01, 2006 11:55 am     Reply with quote
sorry for my English
I'm working with a Pic 16f877a for connect to a Nokia cell with Fbus
in this form PC-->micro-->phone--> and Work well but when I try to send information directly From Micro It does'nt work, Or When I try to Use FORCE_SW. Can any body Please Help me?
this is the Code
#include "C:\1\CCS\aBRIL27\pr1.h"
//#include<PIC16F877A>
#include<stdlib.h> // Standard header for std input/output
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7,STREAM=X,errors)
int i=0;  //
Byte c;
void usart_sync(){ // USART <-> phone syncronization
   for(i=0;i<200;i++)
   fputc(0X55,X);// putc(0x55); // U
   fputc(0xC1,X);//putc(0xC1);
void hwsw(){ // Getting HW/SW info
byte CONST send_frame_hwswinfo[16] = {0x1E,0x00,0x10,0xD1,0x00,0x07,0x00,0x01,
0x00,0x03,0x00,0x01,0x60,0x00,0x72,0xD5}; // Get HW/SW information
for(i=0;i<=15;i++)
Fputc(send_frame_hwswinfo[i],X);
   SET_TRIS_A( 0xFF );
   SET_TRIS_B( 0xFF );
   SET_TRIS_D( 0xFF );
   SET_TRIS_E( 0xFF );
   SET_TRIS_C( 0xFF );
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(VREF_LOW|-2);
   usart_sync();
   hwsw();
         c = fgetc() ;
          fputc(c);
/// and this don't Work
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7,STREAM=X,errors,FORCE_SW)
int i=0;  //
Byte c;
   for(i=0;i<200;i++)
for(i=0;i<=15;i++)
   SET_TRIS_A( 0xFF );
   SET_TRIS_B( 0xFF );
   SET_TRIS_D( 0xFF );
   SET_TRIS_E( 0xFF );
   SET_TRIS_C( 0xFF );
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   usart_sync();
   hwsw();
         c = fgetc() ;
          fputc(c);
cmdrdan
PostPosted: Mon May 01, 2006 6:10 pm     Reply with quote
Check your set_tris statements. You have them all set for inputs, and you're wanting an output somewhere, aren't you?
