Unexpected "Invalid Type Conversion" Error
UFAnders
View user's profile Send private message Send e-mail Visit poster's website AIM Address
PostPosted: Sun Apr 30, 2006 1:28 pm     Reply with quote
Gentlemen-->
I am getting an unexpected type conversion error in my program where I pass two structures into a function as pointers...
Structure definitions:
static struct columnMAX7313
   int8 pixel[8];   //8 bytes store brightness data for 16 pixels!
} columnRealTimeMAX7313;
static struct frameMAX7313
   struct columnMAX7313 columns[64];
} frameRealTimeMAX7313;
Function prototype:
void transformFrame2(unsigned char methodFrame,  struct columnMAX7313 *this_column, struct frameMAX7313 *this_frame);
Function Definition:
   signed int16 cycle=0;
   struct columnMAX7313 tempColumn2;
   switch(methodFrame)
      case shiftRight:
      for(cycle=63; cycle>(-1); cycle--)
         if(cycle!=0)
            tempColumn2 = this_frame->columns[cycle-1];
            this_frame->columns[cycle] = tempColumn2;
            this_frame->columns[cycle] = this_column;
      case shiftLeft:
      for(cycle=0; cycle<64; cycle++)
         if(cycle!=63)
            tempColumn2 = this_frame->columns[cycle+1];
      default:
I call the function like so:
transformFrame2(shiftLeft, &columnRealTimeMAX7313, &frameRealTimeMAX7313);
The area that gives me the error is the "this_frame->columns[cycle] = this_column;" line present in both shift directions. The compiler says "Invalid Type Conversion." However, if I use "this_frame->columns[cycle] = *this_column;" I get an ok compile, but the function doesn't seem to work.
I am using PCH 3.217. Any ideas?
Endless thanks!
PostPosted: Sun Apr 30, 2006 3:06 pm     Reply with quote
The line:
is invalid.
If you think about it, "this_frame->columns[cycle]", is a structure of type columnMAX7313, while "this_column", is a _pointer_ to such a structure. Not suprising you get a complaint.
Second comment, don't use '&columnRealTimeMAX7313', or the other '&' reference. A structure name, just as for an array, _is_ the address of the data, so you are taking the address of the address, and handing this to the routine, which then treats this as the address of the structure. Either just use the structure name, or pass the address of the first element in the structure.
Final comment. How well the compiler handles moving structures as single elements, depends on how recent it is. In the past there were problems, and you may well find it 'safer', to use a memcy, with the size of the structure, to be sure.
UFAnders
PostPosted: Sun Apr 30, 2006 3:41 pm     Reply with quote
Kind Sirs-->
I left the prototypes alone, but I removed the ampersands from the function call for transformFrame2([...]) and changed
to
Now the compiler tells me that "A numeric expression must appear here" at the function calls.
Would anyone be able to inform me of my surely inane mistakes? Laughing
PostPosted: Mon May 01, 2006 2:10 am     Reply with quote
Do what I said, and pass the address of the first element.
Also, I would suggest using memcpy, rather than just passing the structure. The compiler is slightly 'laboured' in handling structures at times, and while the recent versions do seem now to handle passing a whole structure between variables, it is a 'recent enough' feature, that I still feel 'happier' going manual.
