BYTE seconds; // A running seconds counter
BYTE int_count; // Number of interrupts left before a second has elapsed
#int_rtcc // This function is called every time
void clock_isr() { // the RTCC (timer0) overflows (255->0).
// For this program this is apx 76 times
if(--int_count==0) { // per second.
++seconds;
int_count=INTS_PER_SECOND;
What does it mean this expression: (20000000/(4*256*256)) ?
As i can understand 20000000 is clock frequency.
256 is prescaler division. What are 4 and the second 256??
Posted: Sat Apr 29, 2006 7:22 am
True.
The 4 comes from the timers being driven at Fosc / 4. This is related to the PIC using 4 clock cycles to execute a single instruction.
The 256 is the maximum value your timer can count up to before overflowing, at overflow an interrupt is generated and the timer starts counting at 0 again. For 8-bit timers use 256 and for 16 bit timers 65536.
