Multiple duty cycles within one PWM.
RC_PWM
PostPosted: Wed Apr 26, 2006 12:02 pm     Reply with quote
Hello all,
I would like to generate a Variable PWM from 1 to 20Hz. When a period (.5-20mS) is selected, i would like to have 3 variable duty cycles inside this period. searching this forum i came up with code below ( i realize that this code only work to 2mS when duty_100=1023). When i turn OFF and ON CCPR1L inside duty cycle i can only see last duty cycle scope. Can i turn off and on CCPR1L of duty cycle?
Thank you,
RC_PWM
#include <16F877.h>
#device ADC=10
#device *=16
#use delay(clock=8000000)
#FUSES HS, NOWDT, NOPROTECT, BROWNOUT, NOCPD, PUT, NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, BRGH1OK)
char selection;
int16 duty_0=0, duty_12=128, duty_25=256, duty_50=512, duty_62=640,duty_75=786,duty_100=1023;
void main() {
  setup_port_a(ALL_ANALOG);
  output_low(PIN_C1); // Set CCP2 output low
  output_low(PIN_C2); // Set CCP1 output low
  setup_ccp1(CCP_PWM);
  setup_ccp2(CCP_PWM);
  setup_timer_2(T2_DIV_BY_16, 255, 1);
while(TRUE){
   printf("\r\nFreq:\r\n");
   printf("    1) .5mS\r\n");
   printf("    2) 1mS\r\n");
   printf("    3) 2mS\r\n");
   do {
    selection=getc();
  } while((selection<'1')||(selection>'3'));
    switch(selection) {
     case '1' :
                 set_pwm1_duty(duty_25);   // 25% Duty Cycle
// Would like to turn off CCPR1L register
                 set_pwm1_duty(duty_50);
 // Would like to turn off CCPR1L register again
     case '2' :
                 set_pwm2_duty(duty_62);    // 62% Duty Cycle
                 set_pwm2_duty(duty_75);     // 75% Duty Cycle
     case '3' :
                 set_pwm1_duty(duty_50);  // 50% Duty Cycle
                 set_pwm2_duty(duty_50);    // 20% Duty Cycle
   printf("%c\r\n",selection);
     case '1' :
// When turn off CCPR1L register
 // When turn off CCPR1L register again
