For favo I need urgent help with EEPROM of the pic18f4620 I
oscarec60
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Wed Apr 26, 2006 7:41 am     Reply with quote
The proble is the following one, I want that in EEPROM it records me the data that he/she sends me the such keyboard and like it is shown in the code, and then he/she sent them for parallelly for the port TO but for some reason this doesn't make it.
#include <18F4620.h>
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, IESO, BROWNOUT, BORV21, NOPUT, NOCPD, NOSTVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOXINST, NOPBADEN, NOLPT1OSC, NOMCLR
//#define set_tris_d
//#device adc=8
//#use delay(clock=8000000)
//#fuses NOWDT,WDT128,INTRC_IO, NOPROTECT, IESO, BROWNOUT, BORV21, NOPUT, NOCPD, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOXINST, NOPBADEN, NOLPT1OSC, NOMCLR
#zero_ram
//#define output_d
#define LCD_DB4 PIN_C4
#define LCD_DB5 PIN_C5
#define LCD_DB6 PIN_C6
#define LCD_DB7 PIN_C7
#define LCD_RS PIN_C0
#define LCD_RW PIN_C1
#define LCD_E PIN_C2
#include <flex_lcd.c>
// Definiciones globales
unsigned char edge, bitcount;
char got_interrupt;
char interrupt_count;
char status_b7;
#bit INTF_BIT = 0x0B.1
//-------- Tabla de caracteres correspondientes a la pulsación de la tecla
//-------- en modalidad normal (sin pulsar SHIFT)
unsigned char const unshifted[68][3] = {
0x0d,9,0x00,
0x0e,'º',0x00,
0x15,'q',0x37,
0x16,'1',0x07,
0x1a,'z',0x1d,
0x1b,'s',0x26,
0x1c,'a',0x01,
0x1d,'w',0x3a,
0x1e,'2',0x03,
0x21,'c',0x21,
0x22,'x',0x2d,
0x23,'d',0x31,
0x24,'e',0x11,
0x25,'4',0x31,
0x26,'3',0x21,
0x29,' ',0x00,
0x2a,'v',0x0f,
0x2b,'f',0x23,
0x2c,'t',0x36,
0x2d,'r',0x17,
0x2e,'5',0x11,
0x31,'n',0x35,
0x32,'b',0x03,
0x33,'h',0x13,
0x34,'g',0x33,
0x35,'y',0x3d,
0x36,'6',0x23,
0x39,',',0x02,
0x3a,'m',0x25,
0x3b,'j',0x32,
0x3c,'u',0x0d,
0x3d,'7',0x33,
0x3e,'8',0x13,
0x41,',',0x02,
0x42,'k',0x05,
0x43,'i',0x22,
0x44,'o',0x15,
0x45,'0',0x32,
0x46,'9',0x22,
0x49,'.',0x04,
0x4a,'-',0x0c,
0x4b,'l',0x01,
0x4c,'ñ',0x3b,
0x4d,'p',0x27,
0x4e,''',0x00,
0x52,'´',0x00,
0x54,'`',0x00,
0x55,'¡',0x16,
0x5a,13,0x00,
0x5b,'+',0x00,
0x5d,'ç',0x00,
0x61,'<',0x00,
0x66,8,0x00,
0x69,'1',0x01,
0x6b,'4',0x31,
0x6c,'7',0x33,
0x70,'0',0x32,
0x71,'.',0x04,
0x72,'2',0x03,
0x73,'5',0x11,
0x74,'6',0x23,
0x75,'8',0x13,
0x79,'+',0x00,
0x7a,'3',0x21,
0x7b,'-',0x0c,
0x7c,'*',0x00,
0x7d,'9',0x22,
0,0,0
//-------- en modalidad desplazamiento (pulsando SHIFT)
unsigned char const shifted[68][3] = {
0x0d,9,0x00,
0x0e,'ª',0x00,
0x15,'Q',0x37,
0x16,'!',0x16,
0x1a,'Z',0x1d,
0x1b,'S',0x26,
0x1c,'A',0x01
0x1d,'W',0x3a,
0x1e,'"',0x0e,
0x21,'C',0x21,
0x22,'X',0x2d,
0x23,'D',0x31,
0x24,'E',0x11,
0x25,'$',0x00,
0x26,'·',0x00,
0x29,' ',0x00,
0x2a,'V',0x0f,
0x2b,'F',0x23,
0x2c,'T',0x36,
0x2d,'R',0x17,
0x2e,'%',0x00,
0x31,'N',0x35,
0x32,'B',0x03,
0x33,'H',0x13,
0x34,'G',0x33,
0x35,'Y',0x3d,
0x36,'&',0x00,
0x39,'L',0x07,
0x3a,'M',0x25,
0x3b,'J',0x32,
0x3c,'U',0x0d,
0x3d,'/',0x00,
0x3e,'(',0x1b,
0x41,';',0x06,
0x42,'K',0x05,
0x43,'I',0x22,
0x44,'O',0x15,
0x45,'=',0x00,
0x46,')',0x34,
0x49,':',0x12,
0x4a,'_',0x00,
0x4b,'L',0x07,
0x4c,'Ñ',0x3b,
0x4d,'P',0x27,
0x4e,'?',0x0a,
0x52,'¨',0x00,
0x54,'^',0x00,
0x55,'¿',0x0a,
0x5a,13,0x00,
0x5b,'*',0x00,
0x5d,'Ç',0x00,
0x61,'>',0x00,
0x66,8,0x00,
0x69,'1',0x01,
0x6b,'4',0x31,
0x6c,'7',0x33,
0x70,'0',0x32,
0x71,'.',0x04,
0x72,'2',0x03,
0x73,'5',0x11,
0x74,'6',0x23,
0x75,'8',0x13,
0x79,'+',0x00,
0x7a,'3',0x21,
0x7b,'-',0x00,
0x7c,'*',0x00,
0x7d,'9',0x22,
0,0,0
//-------- Tabla de caracteres traducido a Braille
//-------- para caracteres cuando ya ha sido pulsado el SHIFT y le corresponde primero el caracter de mayuscula en Braille
// Definición de protipos
void init_kb(void);
void decode(unsigned char sc);
#int_ext
void int_ext_isr(void);
// Main
int j;
j=0;
//setup_adc_ports(AN0|VSS_VDD);
//setup_adc(ADC_CLOCK_INTERNAL);
setup_adc(ADC_OFF);
// setup_psp(PSP_ENABLED);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
// set_adc_channel( 0 ); //RA0 como entrada
// delay_us(100);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
init_kb();
//lcd_gotoxy(0x00,0x00);
//printf(lcd_putc," \n ");
//-------- Los pins indicados (B0 y B7) son configurados como entradas.
output_float(PIN_B0);
output_float(PIN_B7);
//-------- Activa pullups sobre todos los pins del puerto B.
port_b_pullups(TRUE);
//-------- Espera a que se activen.
delay_us(5);
//-------- Inicializa las variables usadas por la rutina de interrupción
//-------- antes de activar las interrupciones
interrupt_count = 0;
got_interrupt = FALSE;
status_b7 = 0;
//-------- Desde que se activó el modo PULLUPS del puerto B, el estado
//-------- normal del pin B0 es ALTO. La gestión de la interrupción externa
//-------- se gestiona cuando se produce un cambio de nivel ALTO a BAJO.
ext_int_edge(H_TO_L);
//-------- Asegurarse de que el el bit de flag de la interrupción externa
//-------- es borrado antes de activar la gestión de dicha interrupción
//-------- externa.
INTF_BIT = 0;
enable_interrupts(INT_EXT);
//-------- Bucle principal.
//-------- Chequear si se produce alguna interrupción (got_interrupt). Si es así, contar, borrar
//-------- el flag y esperar 50 ms, reactivando la gestión de las interrupciones
if(got_interrupt == TRUE)
//-------- Borrar el flag global que se inicio en la rutina de servicio
//-------- de interrupciones externas.
//-------- Esperar 50 ms para evitar rebotes en los contactos de las teclas.
//delay_ms(50);
//-------- Borrar cualquier interrupción producida durante el periodo de espera.
INTF_BIT = 0;
//-------- Reactivar interrupciones
} // --- End If ---
} // --- End While ---
} // --- End MAIN ---
// Funciones
// Inicialización de teclado.
void init_kb(void)
//-------- Longitud de la trama para cada pulsación y mensaje de bienvenida
bitcount = 11;
printf(lcd_putc,"Dispositivo para\n Sordo-Ciegos ");
// Decodificación de pulsaciones
static unsigned char is_up=0, shift = 0, mode = 0;
unsigned char i;
unsigned char x=0;
//-------- El último dato recibido fue el identificador de Up-Key
if (!is_up)
switch (sc)
//-------- Identificador de Up-Key
case 0xF0 :
is_up = 1;
//-------- SHIFT Izquierdo
case 0x12 :
shift = 1;
//-------- SHIFT Derecho
case 0x59 :
shift = 1;
//-------- ENTER
case 0x5A :
shift = 0;
for(i=0; i == j ;i++)
output_a(read_eeprom(i));
output_a(0x00);
i++;
if(j<16 && x == 0)
printf(lcd_putc,"\n");
j=0;
x=1;
// lcd_gotoxy(0x00,0x00);
j=0;
x=0;
//-------- Si no es ninguno de los identificadores especiales, procesar
//-------- pulsación, localizando caracter en tabla de caracteres.
default:
//-------- Pulsación normal
if(!shift)
for(i = 0; unshifted[i][0]!=sc && unshifted[i][0]; i++);
printf(lcd_putc,"%c", unshifted[i][1]);
if(sc == 0x66)
j--;
write_eeprom(j,unshifted[i][2]);
j++;
//-------- Pulsación + SHIFT presionado
for(i = 0; shifted[i][0]!=sc && shifted[i][0]; i++);
if (shifted[i][0] == sc)
printf(lcd_putc,"%c", shifted[i][1]);
write_eeprom(j,0x28);
j++;
write_eeprom(j,0x00);
j++;
write_eeprom(j,shifted[i][2]);
j++;
} // --- End Switch
//-------- No se permiten 2 0xF0 en una fila
is_up = 0;
switch (sc)
case 0x12 :
shift = 0;
case 0x59 :
shift = 0;
} // --- End Switch
// Rutina de gestión de interrupciones
#int_ext
unsigned char data;
//-------- Los bit 3 a 10 se considerran datos. Paridad, start y stop
//-------- son ignorados
if(bitcount < 11 && bitcount > 2)
data = (data >> 1);
status_b7 = input(PIN_B7);
if((status_b7) == 1)
data = data | 0x80;
//-------- Todos los bits se han recibido
if(--bitcount == 0)
decode(data);
data = 0;
bitcount = 11;
got_interrupt = TRUE;
interrupt_count++;
disable_interrupts(INT_EXT);
PostPosted: Wed Apr 26, 2006 8:42 am     Reply with quote
When posting code please use the 'code' buttons at the start and end of your code section, this will help to keep the formatting of your code intact.
I only had a very quick look at your code, the next line jumped out as an obvious error.
Maybe there are more errors in your program but I don't have time to look into it now.
