Help With Numbers
rtracy
Help With Numbers
PostPosted: Wed Apr 26, 2006 6:34 am     Reply with quote
This version works just fine for making a test pulse.
int y;
int16 low,high;
   setup_adc_ports(AN0);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
y=1;
while (y=1) {
  high = 1;
  low = 19;
  output_high(pin_d5);
  delay_ms(high);
  output_low(pin_d5);
  delay_ms(low);
This version doesn't seem to pass more than 8 bits. I've tried various specifiers but I'm still missing something. So how do I pass a large number? Thanks for any help.
int y;
int16 low,high;
   setup_spi(FALSE);
   setup_vref(FALSE);
y=1;
while (y=1) {
  high = 1000;
  low = 19000;
  delay_us(high);
  output_low(pin_d5);
  delay_us(low);
rberek
PostPosted: Wed Apr 26, 2006 6:41 am     Reply with quote
The delay_x statements only take an 8 bit variable. They will take a 16-bit constant.
rtracy
PostPosted: Wed Apr 26, 2006 7:15 am     Reply with quote
Thanks, Rberek. Reading the manual is key. Smile
I was trying to take a value directly from the 10bit ADC and drop it into a delay statement.
PostPosted: Wed Apr 26, 2006 1:46 pm     Reply with quote
See this thread for the long_delay_us() function:
http://www.ccsinfo.com/forum/viewtopic.php?t=16656&start=1
rtracy
PostPosted: Thu Apr 27, 2006 3:42 pm     Reply with quote
Thanks!
