hundil Guest
LCD_init |
Posted: Tue Apr 25, 2006 10:43 am |
Hi everybody
This is a part of my whole code below.
The problem is that LCD is not starting up properly.
Sometimes, Wrong characters are printed or nothing is appeared on LCD .
After a few resets, it works properly
Is there any problem with interrupts enable and disable sequence or place.
Any idea will be appreciated...
hundil
#include "LCD.C"
disable_interrupts(GLOBAL);
clear_interrupt(int_ccp1);
clear_interrupt(int_ccp2);
clear_interrupt(int_timer3);
disable_interrupts(INT_TIMER3);
disable_interrupts(INT_CCP1);
disable_interrupts(INT_CCP2);
disable_interrupts(INT_AD);
port_b_pullups(false);
setup_adc_ports(AN0);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_timer_3(T3_INTERNAL|T3_DIV_BY_1);
set_tris_a(0x09);
set_tris_b(0xf1);
set_tris_c(0xA6);
set_tris_e(0x00);
disable_interrupts(int_ad);
lcd_init();
output_high(PIN_C0);
printf(lcd_putc,"\f**SYK**");
output_low(PIN_C0);
setup_ccp1(CCP_CAPTURE_RE);
setup_ccp2(CCP_CAPTURE_RE);
set_timer3(15000);
enable_interrupts(INT_TIMER3);
enable_interrupts(INT_CCP1);
enable_interrupts(INT_CCP2);
delay_ms(5);
while(!input(PIN_B5)) output_high(PIN_A1);
output_low(PIN_A1);
do{.......
}while(1);
Posted: Tue Apr 25, 2006 11:05 am |
Is your TRIS setup correct ?
My advice:
1. Get rid of the #fast_io() statement and get rid of these tris statements.
Let the compiler handle the TRIS. You're using CCS pin i/o functions.
The compiler will automatically setup the correct TRIS if you use
"standard i/o" mode instead of "fast_io". Standard i/o mode is the
default mode of the compiler.
set_tris_a(0x09);
set_tris_b(0xf1);
set_tris_c(0xA6);
set_tris_e(0x00);
2. If that doesn't work, then edit the lcd_init() function in LCD.C,
and increase the initial delay_ms() value to 50 ms. CCS has it set
for 15 ms, but some LCD's require a longer delay. |
