Set Target-Filename in C-Code possible (under MPLAB) ???
RHA
PostPosted: Tue Apr 25, 2006 7:59 am     Reply with quote
is it possible to set the name of the target-file (*.hex) via a directive in the C-Code ???
I want to set the filename of the compilated HEX-File without the need to rename the Source-Files. If possible i want to do that in the C-Source. I work always under MPLab with plugin for the CCS.
ciao
RHA
