new to PCM
eetrung
new to PCM
PostPosted: Mon Apr 24, 2006 12:03 pm     Reply with quote
I just bought and installed PCM. Been Trying to run the sample code in the compilerto see if everything OK.
Built Succeeded in MPLAB 7.30. Why I could not run "Animate" to walk thru the C code?
Do I miss something here.
Thanks for your help.
eetrung
Newbie
PostPosted: Mon Apr 24, 2006 1:43 pm     Reply with quote
Did you fully install the compiler, including the CCS "Plug-in", etc. ?
Did you go to the Debugger menu in MPLAB and then in the Select Tool
menu, did you pick MPLAB SIM ?
In the Configure menu, did you go to Select Device, and make sure
it matches the PIC specified in the #include statement in your program ?
Then compile and in the Debugger menu, select Animate.
Using the UART1 output window, the following program slowly
spells out Hello World. It works.
#include <16F877.H>
   printf("Hello World\n\r");
Instructions on how to use UART1 to display output in MPLAB simulator:
http://www.ccsinfo.com/forum/viewtopic.php?t=23408&start=1
eetrung
PostPosted: Tue Apr 25, 2006 5:56 am     Reply with quote
I followed your steps. It works out fine.
Newbie
