byte or int (int 8)??
mewanchyna
PostPosted: Mon Apr 24, 2006 6:27 am     Reply with quote
When it comes to data types, I've noticed that in some examples,the word "byte" is used as a data type specifier. I was unable to find the usage or definition of this data type in the manual or help file. The editor doesn't even highlight this keyword. I imagine the the identifier "byte" is simply an unsigned int 8. I just want to be sure before I make this conclusion.
rberek
PostPosted: Mon Apr 24, 2006 6:41 am     Reply with quote
You are probably thinking if #byte, which is described in the manual. It is used to attach a name to a memory address.
Charlie U
PostPosted: Mon Apr 24, 2006 7:28 am     Reply with quote
The byte type is defined in the device header files.
#define BYTE int
Humberto
PostPosted: Mon Apr 24, 2006 7:34 am     Reply with quote
Yes you are right.
For the CCS Compiler a byte, int, int8, char have the same size: 8 bits.
I donīt know what editor are you using but highlighted words depends if they are included or not in a user accesible/modificable list.
Humberto
PostPosted: Mon Apr 24, 2006 7:35 am     Reply with quote
The BYTE type is defined in the header file for your PIC processor. For example <pic18f458.h> defines:
#define BYTE int
mewanchyna
PostPosted: Mon Apr 24, 2006 9:23 am     Reply with quote
Thanks for the replies in record time!. To clarify, I'm not talking about the "#byte". As mentioned, it's when a data type is specified (see sample code). Is "byte" leftover from another compiler? If it is defined in the header files, perhaps it's to maintain backwards compatability from a previous compiler. I'm using the CCS ver. 3.249 PCWH interface. If it is included in the header file, one would assume that they would have included int the list of recognized keywords. Nevertheless, these are minor points, my question has been answered and I'm happy again!
void lcd_send_nibble( BYTE n ) {
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
      lcd.enable = 0;
