		| Author | Message |
		| treitmey
				| Typemod using custom external ram functions |
				|  Posted: Thu Apr 20, 2006 2:38 pm |   |
				| PCWH R3.249  I am seeing a typemod bug I can't explain. I am using typemod for access to external memory as shown here.
 http://www.ccsinfo.com/faq.php?page=addressmod
 I made shell read and write functions.
 The write function just prints the proposed data.
 If I put in a line for "record2" I see expected data.
 If I take that line out, I don't see the expected data.
 Does anyone understand whats going on here?
  	  | Code: |  	  | #include <18F452.H> #use delay(clock=40000000)
 #fuses h4,nowdt,noprotect,nolvp
 #use rs232(baud=19200,xmit=PIN_C0,invert,stream=DEBUG,disable_ints) // stderr(same as debug)
 #case
 #zero_ram
 mr(int32 addr,int8 *data,int8 size);
 mw(int32 addr,int8 *data,int8 size);
 typemod <,mr,mw,0x0000,0xFFFF>RAM;//24 bit address ,16 bit range
 struct  rec_struc //rec definition
 int16 pc;
 int16 ai;
 int8  tz;
 }RAM record;
 int16 RAM record2;
 setup_adc_ports(NO_ANALOGS);
 set_tris_a(0);set_tris_b(0);set_tris_c(0);set_tris_d(0);set_tris_e(0);
 printf("Start\n\r");
 record.pc=0x1122;
 record.ai=0x3344;
 record.tz=0x55;
 record2  =0x6677;  //<----------------Take out this line and it BLOWS up
 printf("DONE !\n\r");
 //======================multi_write===========================//
 int8 x;
 int32 start_size;
 start_size=size;
 fprintf(DEBUG,"write addr=%lu s=%u ",addr,size);
 for(x=0;x<size;x++,data++){
 fprintf(DEBUG,"0x%X,",*data);
 fprintf(DEBUG,"\n\r");
 return(TRUE);
 //======================multi_read===========================//
 mr(int32 addr,int8 *data,int8 size){
  	  | Code: |  	  | //--BAD--
 write addr=0 s=2 0x22,0x00,
 write addr=2 s=2 0x44,0x02,
 write addr=4 s=1 0x55,
  	  | Code: |  	  | //--Good--
 write addr=0 s=2 0x22,0x11,
 write addr=2 s=2 0x44,0x33,
 write addr=5 s=2 0x77,0x66,
		| PCM programmer
				|  Posted: Thu Apr 20, 2006 3:34 pm |   |
				|  	  | Quote: |  	  | struct  rec_struc //rec definition {
 int16 pc;
 int16 ai;
 int8  tz;
 }RAM record;
 int16 RAM record2;
 One thing you might try is to take the "record" declaration out
 of the structure and typdef the structure instead.   Then use the
 type to declare "record" on a separate line of code.   I haven't
 tested this but it's something to try.   The way you describe the
 problem implies that possibly CCS is looking for a typedef, and
 they may have only tested it in that manner.
		| treitmey
				|  Posted: Thu Apr 20, 2006 3:50 pm |   |
				| Thanks Seems to work.  Doesn't give me a "warm fuzzy" feeling tho.
 #case
 #zero_ram
 int8 ERRORS;
 #define FRAM_CHIPS 4
 //-------prototype-------------------------------
 int16 pc;
 int16 ai;
 int8  tz;
 struct rec_struc RAM record;
 record.pc=0xBBAA;
 record.ai=0xDDCC;
 record.tz=0xFF;
 int8 x;
 int32 start_size;
 start_size=size;
 return(TRUE);
 I responded so fast, cause I came to that same conclusion.  Didn't know why it acted like that tho.
		| treitmey
				|  Posted: Thu Apr 20, 2006 4:08 pm |   |
				| BTW: #byte and #locate will also screw up typemod variables
 It looks like the compiler understands the use,.. but the second
 byte of data transfered is corrupted again.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
