Know Guest
| Does V3.224 have printf("%6.4w", ADC32)? |
Posted: Thu Apr 20, 2006 12:52 pm |
I would like to print out 4 decimal numbers, I don't really want to use float. I try
| Code: | | printf("%6.4w",ADC32); | on V3.224, it gave me a "Printf format (%) invalid"
work arround?
int32 ADC32;
delay_ms(10);
ADC32=read_adc();
thank you
RC |
Posted: Thu Apr 20, 2006 1:33 pm |
| Quote: | | Does V3.224 have printf("%6.4w", ADC32)? |
Sometimes this information is available on the CCS versions page:
http://www.ccsinfo.com/devices.php?page=versioninfo
It says:
| Quote: | | 3.231 New printf specifications %g and %w added and %f improved |
So that feature came out after your version.
| Quote: | | I would like to print out 4 decimal numbers |
The A/D converter in your PIC likely returns 10 bits. You don't
need an int32 to hold this value. You can use an int16.
The value returned by read_adc() is an unsigned integer,
from 0 to 1023. It's not a floating point value.
You can display the value with printf by using the "%lu" format
specification. To display leading spaces when there are less
than 4 digits, you can use "%4lu" with CCS to do this. See the
example program below. It displays:
| Code: | #include <16F877.H>
int16 value;
value = 55;
printf("%4lu\n\r", value);
value = 1023;
Know Guest
Posted: Thu Apr 20, 2006 2:04 pm |
Got it
Thank you
RC |
