How autocalibrate a Joystick (PIC 18f2550)
Alain
PostPosted: Tue Apr 18, 2006 10:18 pm     Reply with quote
I design a basic controler USB for a Joystick with a PIC 18f2550.
It works fine Smile , but i hope that the joystick was autocalibrate when the controler is plugged.
I think that i need to know Vcenter , Vmax et Vmin but i haven't any idea for use this.
if anyone might offer some assistance?
Thinks
here my HID Descriptor
const char USB_CLASS_SPECIFIC_DESC[] = {
      0x05, 0x01,       // Usage Page = Generic Desktop
      0x09, 0x04,       // Usage = Joystick
      0xa1, 0x01,       // Collection = Application
      0x05, 0x02,       // Usage Page (Simulation Controls)
      0x09, 0xBB,       // Usage (Throttle)
      0x15, 0x00,       // Logical  Minimum (0)
      0x26, 0xFF,0x00   // Logical  Maximum (255)
      0x35, 0x00,       // Physical Minimum (0)
      0x46, 0xFF,0x00,  // Physical Maximum (255)
      0x75, 0x08,       // Report Size (8)
      0x95, 0x01,       // Report Count (1)
      0x81, 0x02,       // Input (Data,Var,Abs)
      0x09, 0x01,       // Usage (Pointer)
      0xA1, 0x00,       // Collection (Physical)
      0x09, 0x30,       // Usage (X)
      0x09, 0x31,       // Usage (Y)
      0x15, 0x81,       // Logical  Minimum (-127)
      0x25, 0x7F,       // Logical  Maximum (+127)
      0x95, 0x02,       // Report Count (2)
      0xC0,             // End_Collection
      0x05, 0x09,       // Usage Page (Button)
      0x19, 0x01,       // Usage Minimum (Button1)
      0x29, 0x08,       // Usage Maximum (Button8)
      0x25, 0x01,       // Logical Maximum (1)
      0x45, 0x01,       // Physical Maximum (1)
      0x95, 0x08,       // Report Count (8)
      0x75, 0x01,       // Report Size (1)
      0x65, 0x00,       // Unit (None)
      0xC0              // End Collection
Here the main code
#define Throttle     TxUSB[0]
#define X            TxUSB[1]
#define Y            TxUSB[2]
#define Boutons      TxUSB[3]
   int8 Trim[2];
   int8 TxUSB[5];
   int8 Buffer;
while (TRUE)
      if(usb_enumerated())             //si le PicUSB a été configuré
         // Lecture des entrées analogiques
               set_adc_channel( 0 );   // Selection Voie 0
               delay_us(40);
               Buffer = Read_ADC();    // Lecture du Canal 0 : X
               X = Buffer -128 ;           // Centrage de l'axe à 2.5V
               set_adc_channel( 1 );   // Selection Voie 1
               delay_us(40);
               Buffer = Read_ADC();    // Lecture du Canal 1 : Y
               Y = Buffer -128 ;
               set_adc_channel( 2 );   // Selection Voie 2
               delay_us(40);
               Throttle = Read_ADC();  // Lecture du Canal 2 : Throttle
               set_adc_channel( 3 );   // Selection Voie 3
               delay_us(40);
               Buffer = Read_ADC();    // Lecture du Canal 3 : Rudder
               Rudder = Buffer - 128 ;
               set_adc_channel( 4 );   // Selection Voie 4
               delay_us(40);
               Buffer = Read_ADC();    // Lecture du Canal 4 : Axe ?
               Trim[1] = Buffer - 128 ;
               delay_us(40);
        // Lecture des entrées numériques
               Boutons = input_b();
       // Envoie des entrées sur le port USB
               usb_put_packet(1, TxUSB, 4, USB_DTS_TOGGLE); //envoie d'un paquet de 4 octets sur EP1 vers le PC
               delay_ms(10);
kender
PostPosted: Wed Apr 19, 2006 12:52 am     Reply with quote
Hm... This might be an interesting problem.
Why do you need to calibrate your joystick every time you plug it into the USB port? You could calibrate it once and store the calibration constants in the PIC's EEPROM.
Could you post the description of your hardware (electrical and mechanical)?
Do you want the calibration to be completely automatic? If not, you could ask the user to do certain manipulations with joystick such as "move the stick all the way to the top-right and press a button" then "move the stick all the way to the bottom-left and press a button".
PostPosted: Sat Jul 05, 2008 9:47 pm     Reply with quote
does anyone have the full working code for a simple joystick? I'm not sure how I would set the descriptor up.
