controlling GSM modem
Goto page 1, 2  Next
prajeesh
PostPosted: Mon Apr 17, 2006 4:47 am     Reply with quote
hi,
am trying to communicate with a GSM modem using rs232. am facing some problem while reading the response from the modem. i used #int_rda for triggering the read operation. am not able to read the response from the modem
can anyone help me in this
thanks
prajeesh
rberek
PostPosted: Mon Apr 17, 2006 5:25 am     Reply with quote
You're going to have to supply a lot more detail than this...
prajeesh
PostPosted: Mon Apr 17, 2006 5:54 am     Reply with quote
hi,
am using 16f877a and wavecom GSM modem to send sms by giving AT command (AT+CMGS="xxxx....."\r). am able to send the message, but unable to read the response from the modem... think there may be timing issues....
please provide ur suggetions,
thanks
prajeesh
rberek
PostPosted: Mon Apr 17, 2006 6:07 am     Reply with quote
Post the relevant code and your compiler version.
One thing that seems to trip up nearly everybody is that 9 times out of ten a NULL modem cable is required but is used zero times out of ten.
r.b.
PostPosted: Mon Apr 17, 2006 6:13 am     Reply with quote
#include "G:\Work\pic\work_outs\serial\serial_send.h"
#include <string.h>
#byte trisc = 0x87
#byte portc = 0x07 // defining port address
#byte trisd = 0x88
#byte portd = 0x08
#define BUFFER_SIZE 96
byte buffer[BUFFER_SIZE];
byte next_in = 0;
byte next_out = 0;
byte count = 0;
void init()
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
void tx_data()
putc('A'); // Transmit "AT" through serial port
putc('T');
putc('+');
putc('C');
putc('M');
putc('G');
putc('S');
putc('=');
putc('"');
putc('+');
putc(0x39);
putc(0x31);
putc(0x39);
putc(0x38);
putc(0x39);
putc(0x34);
putc(0x35);
putc(0x32);
putc(0x34);
putc(0x35);
putc(0x39);
putc(0x36);
putc('"');
putc('\r');
putc('H');
putc('e');
putc('l');
putc('l');
putc('o');
putc(0x1A);
#int_rda
void rx_serial_data()
byte t;
count += 1; // counting total number of interrupts occured
#asm
BSF 0x08, 0
#endasm
buffer[next_in] = getc(); // get the data(single character) from serial port
t=next_in;
next_in=(next_in+1) % BUFFER_SIZE;
if(next_in==next_out)
next_in=t; // Buffer full !!
void check_serial_data()
char resp_data[] = "OK";
if(strstr(start_point, resp_data)){
#asm
BSF 0x08, 2
#endasm
byte i;
trisc = 0x80; // RC7 as i/p & RC6 as o/p. RC6 - Tx pin & RC7 - Rx pin
trisd = 0x00; // portd as o/p
portd = 0x00;
memset(buffer, 0, BUFFER_SIZE);
enable_interrupts(global);
enable_interrupts(int_rda); // Enable receive data available interrupt
init(); // initialize peripherals
tx_data();
delay_ms(15000);
for(i = 0; i < count; i ++){
#asm
BSF 0x08, 1
#endasm
#asm
BCF 0x08, 1
#endasm
count = 0;
check_serial_data();
the response data is checked at check_serial_data();
The compile version is PCW 3.094
rberek
PostPosted: Mon Apr 17, 2006 6:56 am     Reply with quote
How have you set up the RS232? What is your processor clock frequency?
What fuses have you set? What type of connection does your PIC have to the GSM modem (.i.e. straight through cable, NULL modem cable, etc).
prajeesh
PostPosted: Mon Apr 17, 2006 7:35 am     Reply with quote
hi reberk,
thanks for ur co op..
finally i got it. ...... i made mistake in the response format of AT+cmgs...
thanks, thanks a lot....
prajeesh
prajeesh
PostPosted: Mon Apr 17, 2006 7:36 am     Reply with quote
reberk,
i have used straight through cable...
prajeesh
rberek
PostPosted: Mon Apr 17, 2006 7:41 am     Reply with quote
I'm glad its working for you!
I didn't give you any assistance though. You figured it out yourself.
The more information you give when posting a question, the quicker the responses will be.
THe question about the cable is because one of the main causes of problems on this forum, as far as RS232 communication is concerned, is that people try to get two devices to talk to each other when each device was designed to talk to a PC. When they talk to each other, they need a NULL modem cable.
prajeesh
PostPosted: Mon Apr 17, 2006 8:11 am     Reply with quote
hi reberk,
i would like to know some details about doing "Higher studies" in canada. am from india... can i have ur mail id pls...if u dont mind....
thanks,
prajeesh
rberek
PostPosted: Mon Apr 17, 2006 9:18 am     Reply with quote
Sorry but I don't give out that info. Besides, I graduated university 19 years ago and have no current info on the subject.
Good luck...
khawer102
PostPosted: Mon Apr 17, 2006 1:15 pm     Reply with quote
hey prajeesh
i woas working on the same thing. PIC18F452 and GSM modem. i can send the commands to the modem but i am having problem getting the response.
can you plz give me your code for recieving response.
thank you
khawer
prajeesh
PostPosted: Mon Apr 17, 2006 11:23 pm     Reply with quote
hi khawer,
this is my code....
#include <string.h>
#byte trisc = 0x87
#byte trisd = 0x88
#byte portd = 0x08
#define BUFFER_SIZE 40
byte next_in = 0;
byte next_out = 0;
byte count = 0;
void init()
setup_spi(FALSE);
void tx_ate0()
putc('A');
putc('T');
putc('E');
putc(0x30);
putc('\r');
void tx_data()
tx_ate0();
putc('T');
putc('+');
putc('C');
putc('M');
putc('G');
putc('S');
putc('=');
putc('"');
putc('+');
putc(0x39);
putc(0x31);
putc(0x39);
putc(0x38);
putc(0x39);
putc(0x34);
putc(0x35);
putc(0x32);
putc(0x34);
putc(0x35);
putc(0x39);
putc(0x36);
putc('"');
putc('\r');
putc('H');
putc('e');
putc('l');
putc('l');
putc('o');
putc(0x1A);
#int_rda
byte t;
#asm
BSF 0x08, 0
#endasm
t=next_in;
char resp_data[] = "\r\n\r\nOK\r\n";
if(strstr(buffer, resp_data)){
#asm
BSF 0x08, 2
#endasm
byte i;
portd = 0x00;
enable_interrupts(int_rda); // Enable 'receive data available' interrupt
tx_data();
delay_ms(15000);
#asm
BSF 0x08, 1
#endasm
#asm
BCF 0x08, 1
#endasm
count = 0;
i have used an LED to blink, when i get the correct response from the modem. i sent an sms using GSM modem and PIC
prajeesh
PostPosted: Mon Apr 17, 2006 11:24 pm     Reply with quote
hi reberk,
its ok...thanks for ur help...
prajeesh
khawer102
PostPosted: Tue Apr 18, 2006 4:29 pm     Reply with quote
Hi Prajeesh
i used ur code for reading the response from the modem.
i also tried using AT+CMGR=1 for reading the SMS stored at sim location 1 and it works just fine. except that i have not been able to understand the format with which the modem sends the response. I read ur other Post in which you stated that you wanted to read "Hi" from the returing string. i am sure you can make your own function for checking if the complete string has "Hi" in it.
i also wanted to thank you for the code that you gave me. it was of a lot of help.
i would also like to know what project you have been working on which invloves PIC and GSM modem. can we chat on MSN. if you dont mind that happening
Thank you
Goto page 1, 2  Next
Page 1 of 2
