What is the distance that a Bluetooth chip can transmit?
arrow
PostPosted: Thu Apr 13, 2006 8:42 am     Reply with quote
Hi
Say I am going to use the Taiyo Yuden bluetooth SPP (EYMF2CAMM-XX ), can someone please tell me the range (in meters) for direct line of sight connection?
All the best
a.
Mark
PostPosted: Thu Apr 13, 2006 11:22 am     Reply with quote
Did you read the datasheet?
PostPosted: Fri Apr 14, 2006 1:16 am     Reply with quote
Hi Mark
I have looked at the data sheet but it does not tell me the range in feet (or meters) of the system.
I was wondering if Bluetooth has a range, or does it depend on the chips usd?
Thank you
a.
arunb
PostPosted: Fri Apr 14, 2006 1:37 am     Reply with quote
Why don't you ask the manufacturers ?? , you could also tell them to provide this information on the datasheet.
thanks
arunb
libor
PostPosted: Fri Apr 14, 2006 2:05 am     Reply with quote
A Class 1 BT device has a range about 100 meters, Class 2 bluetooth's range is about 10 meters.
PostPosted: Fri Apr 14, 2006 12:53 pm     Reply with quote
Hi Libor
I am new to this- the Class 1BT you refer to- what protocol does it use? and can you recommend some chip sets that I can use to transmit over 100m of open field? (Direct line of sight)
Thank you
a.
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Fri Apr 14, 2006 4:09 pm     Reply with quote
Anonymous wrote:
... can you recommend some chip sets that I can use to transmit over 100m of open field? (Direct line of sight)
A couple of years ago I had researched the possibility of adding a Bluetooth chipset to one of my products. I have contacted TI (one of the major manufactureres of teh BT chips) and they told me that I need to get the approval of the BT SIG before they sell me the chips. At that point I gave up. May be things are easier today.
However, there are tones of BT modules, which are much more friendly then BT chipsets. For example:
http://www.blueradios.com/hardware.htm#BRC11
http://www.parallax.com/detail.asp?product_id=30068
Also, serch this forum for "Bluetooth module".
arrow
PostPosted: Sat Apr 15, 2006 3:40 am     Reply with quote
Hi Kender
Thank you for the web pages- I am beginning to understand.
I will definately go with the module.
Just for clarification:
If I want to transmit over say 100meter and I want to use for e.g. the BlueStamp on http://www.blueradios.com/hardware.htm
will I need TWO modules? (One as a receiver and one as a transmitter?)
Once again thank you
Regards
a.
