how to secure communication? DES or what?
cagacug
PostPosted: Wed Apr 12, 2006 3:22 am     Reply with quote
I want to secure some functions in client PICs which are connected to a non-secure network. If I use some ecryption algorithm with key, OK the PICs are secure but the asking PIC will have to send the same encrypted data everytime it communicates with another client. If a hacker listens the net and re-transmits this encrypted data without knowing the de-crypted password, the client will accept this also.
How this problem can be solved in C?
Any idea...
VanHauser
PostPosted: Thu Apr 13, 2006 1:09 am     Reply with quote
You can use a 16- or 32-bit counter value that is sent encrypted and updated after every successful reception both at the transmitter and at the receiver side. The transmitter and the receiver should be syncronised with this counter and it should be equal on both sides. This way, a captured and re-sent packet is very unlikely to be accepted as the counters will not match. The Keeloq algorithm from Microchip uses a scheme like this.
cagacug
PostPosted: Thu Apr 13, 2006 3:14 am     Reply with quote
Seems to be a good way, thanks lot.
jds-pic
PostPosted: Thu Apr 13, 2006 9:59 am     Reply with quote
the problem you describe is called a "replay attack":
http://en.wikipedia.org/wiki/Replay_attack
this is a well understood, well characterized problem in modern cryptography. don't reinvent the wheel; instead, get yourself a copy of the bible, called "Applied Cryptography: Protocols, Algorithms, and Source Code in C" by Bruce Schneier. this book has theory, examples, and C code snippets for you.
http://www.amazon.com/gp/product/0471117099/103-5648865-8321415
Cryptographic techniques have applications far beyond the obvious uses of encoding and decoding information. For Internet developers who need to know about capabilities, such as digital signatures, that depend on cryptographic techniques, there's no better overview than Applied Cryptography, the definitive book on the subject. Bruce Schneier covers general classes of cryptographic protocols and then specific techniques, detailing the inner workings of real-world cryptographic algorithms including the Data Encryption Standard and RSA public-key cryptosystems. The book includes source-code listings and extensive advice on the practical aspects of cryptography implementation, such as the importance of generating truly random numbers and of keeping keys secure.
jds-pic
cagacug
PostPosted: Thu Apr 13, 2006 11:56 am     Reply with quote
You are absolutely right, seems to be a good book and I never regret to pay for books. But does this book have a PIC side look? (just asking as you seem to read this book) I mean the code used in internet w TCP/IP is an example but not a solution for PICs.
jds-pic
PostPosted: Thu Apr 13, 2006 12:33 pm     Reply with quote
you will need to scale the solutions to fit the limitations (RAM, speed, etc) of your chosen processor. this is always the case. there are more than enough examples in the noted text which will aid in implementing a solution. you don't have to go all out, just follow the principles in the text.
jds-pic
GUEST
PostPosted: Fri Apr 14, 2006 4:40 am     Reply with quote
Have a look @ http://www.ccsinfo.com/forum/viewtopic.php?t=25422&highlight=xtea
And AN953 from Microchip
there is plenty out on the web..
I hope this has helped.
