Color LCD routines - Nokia 6100? / Epson S1D15G10
Goto page 1, 2  Next
amcfall
PostPosted: Wed Mar 22, 2006 5:43 pm     Reply with quote
This is for an LCD (128x128, 4096 colors) I bought from here:
http://www.sparkfun.com/commerce/product_info.php?products_id=569
I guess it's a Nokia clone, I don't know, I just bought a few because they were cheap. Here's some basic code for initialization and a pixel write function. I still need to experiment a little with the contrast and stuff, but on the 2 I have this code looks OK.
//basic routines to drive an ERpson S1D15G00 series based LCD, like the ones from sparkfun.com
// Epson S1D15G10 Command Set and init sequence stolen from sparkfun.com example source code
#include <18F4620.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES BORV21                   //Brownout reset at 2.1V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
//#FUSES DEBUG
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
//#FUSES MCLR
#use delay(clock=8000000)
#DEFINE   _LCDPWR PIN_D1 //LCD defines
#DEFINE CS PIN_A5
#DEFINE LCDCLOCK PIN_C3
#DEFINE LCDDATA PIN_C5
#DEFINE _RESET PIN_C4
#DEFINE BLCONTROL PIN_D0
#define DISON       0xaf
#define DISOFF      0xae
#define DISNOR      0xa6
#define DISINV      0xa7
#define COMSCN      0xbb
#define DISCTL      0xca
#define SLPIN       0x95
#define SLPOUT      0x94
#define PASET       0x75
#define CASET       0x15
#define DATCTL      0xbc
#define RGBSET8     0xce
#define RAMWR       0x5c
#define RAMRD       0x5d
#define PTLIN       0xa8
#define PTLOUT      0xa9
#define RMWIN       0xe0
#define RMWOUT      0xee
#define ASCSET      0xaa
#define SCSTART     0xab
#define OSCON       0xd1
#define OSCOFF      0xd2
#define PWRCTR      0x20
#define VOLCTR      0x81
#define VOLUP       0xd6
#define VOLDOWN     0xd7
#define TMPGRD      0x82
#define EPCTIN      0xcd
#define EPCOUT      0xcc
#define EPMWR       0xfc
#define EPMRD       0xfd
#define EPSRRD1     0x7c
#define EPSRRD2     0x7d
#define NOP         0x25
void write_lcd(int1, unsigned int);
void init_lcd(int1);//0== 8 bit color, 1== send 16 bits (4096 color pallete)
void LCD_pixel_write8(unsigned int8, unsigned int8, unsigned int8);//8 bit color
void LCD_pixel_write16(unsigned int8, unsigned int8, unsigned int16);//takes a 16 bit color (RGB565) and shifts down to 12
void fill8(void);
void fill12(void);
void backlight_on(void);
void backlight_off(void);
   unsigned int16 counter=0;
   unsigned int x,y;
   int8 eepromdata=123;
   long int eepromaddress=0;
   setup_wdt(WDT_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_low_volt_detect(FALSE);
      init_lcd(0);
      fill8();
      delay_ms(2000);
      init_lcd(1);
      fill12();
      delay_ms(2000);
void LCD_pixel_write8(unsigned int8 x, unsigned int8 y, unsigned int8 color)//8 bit color // x and y range 1-130 color 0-255 (RRRGGGBB)
   if ((x > 130) | (x < 1) | (y > 130) | (y < 1))
      return;
   x=x+1;
   y=y-1;
   write_lcd(0, 0x75);//page start/end ram
   write_lcd(1, x);
   write_lcd(1, 131);
   write_lcd(0, 0x15);//column start/end ram
   write_lcd(1, y);
   write_lcd(1, 129);
   write_lcd(0, RAMWR);//RAM WRITE
   write_lcd(1, color);
void LCD_pixel_write16(unsigned int8 x, unsigned int8 y, unsigned int16 color)// x and y range 1-128 color 16 bit (RRRRRGGGGGGBBBBB)
   unsigned int8 colorhigh,colorlow,red,green,blue,data1,data2,data3;
      return;
   x=x+1;
   y=y-1;
   colorhigh=make8(color,1);//high byte
   colorlow=make8(color,0);//low byte
   red = (colorhigh >> 3);
   green = ((colorhigh & 0b00000111) << 3) + ((colorlow & 0b11100000) >> 5);
   blue = (colorlow & 0b00011111);
   red=red>>1;//red was 5 bits, all now need to be 4
   green=green>>2;//green was 6 bits
   blue=blue>>1;
   data1=((red<<4)+green);//send data:RRRRGGGG
   data2=((blue<<4)+red);//BBBBRRRR
   data3=((green<<4)+blue);//GGGGBBBB
   write_lcd(1, x);
   write_lcd(1, 131);
   write_lcd(1, y);
   write_lcd(1, 129);
   write_lcd(0, RAMWR);//ram write
   write_lcd(1, data1);
   write_lcd(1, data2);
   write_lcd(1, data3);
void fill12(void)
   unsigned int16 i;
   unsigned int8 x;
   write_lcd(0, PASET);//page start/end ram
   write_LCD(1, 2);//for some reason it starts at 2
   write_LCD(1, 131);
   write_lcd(0, CASET);//column start/end ram
   write_LCD(1, 0);
   write_LCD(1, 129);
   write_lcd(0, RAMWR);//write a background
   for (i=0; i< 16900; i++)
      write_LCD(1, 0x0000);//black
   for (x=1;x<=130;x++)//draw a border
      lcd_pixel_write16(x,1,0xFBFF);
      lcd_pixel_write16(x,130,0xFBFF);
      lcd_pixel_write16(1,x,0xFBFF);
      lcd_pixel_write16(130,x,0xFBFF);
void fill8(void)
   unsigned int16 i;
   unsigned int8 x;
   write_LCD(1, 131);
   write_LCD(1, 0);
   write_LCD(1, 129);
         write_LCD(1, 0x00);      //black
      lcd_pixel_write8(x,1,0xFF);
      lcd_pixel_write8(x,130,0xFF);
      lcd_pixel_write8(1,x,0xFF);
      lcd_pixel_write8(130,x,0xFF);
   output_high(blcontrol);
   output_low(blcontrol);
Avery
newby
PostPosted: Sun Apr 09, 2006 2:28 am     Reply with quote
hi amcfall, great stuff !
It is indeed the display of the Nokia 6100.
I also have some of these displays but didnīt find the time to port available codes of other uCs by myself. Therefore i am very thankfull to find your work here !
But what about the contrast and the other stuff - did you solve these problems ?
newby
PostPosted: Tue Apr 11, 2006 6:35 am     Reply with quote
@amcfall:
unfortunately very important functions are missing in your code:
-> "init_lcd" and "write_lcd"
please post them also !!!!!
amcfall
PostPosted: Tue Apr 11, 2006 6:53 am     Reply with quote
newby wrote:
@amcfall:
DohH! I'll post that as soon as I remember.
I haven't done any more work, I'll have new boards here soon and I'll try different supply voltages and contrast settings then.
Avery
Storic
PostPosted: Tue Apr 11, 2006 7:04 am     Reply with quote
I found this while reviewing http://www.hobbypic.com/index.php?option=com_content&task=view&id=15&Itemid=36
I'm not sure if the screen are the same however there is a download that give you code in C.
Andrew
What has been learnt if you make the same mistake? Wink
newby
PostPosted: Tue Apr 11, 2006 10:12 am     Reply with quote
@amcfall:
thanks a lot, we are waiting Very Happy !!!!!!!
@Storic:
..you can find J1Mīs code also in this code library, but his glcd is only valid for the PHILIPS controller, not for the epson !
amcfall
PostPosted: Thu Apr 13, 2006 3:19 pm     Reply with quote
void write_lcd(int1 LCDmode, unsigned int data)//mode ==0 send a command, mode==1 sends data
   if (!LCDmode)
      output_low(LCDDATA);//when entering commands: SI=LOW at rising edge of 1st SCL
      output_high(LCDDATA);//send data
   output_low(LCDCLOCK);
   output_high(LCDCLOCK);
   //send data, 8th bit first
   if (data & 128)
   //7th bit
   if (data & 64)
   //6th bit
   if (data & 32)
   //5th bit
   if (data & 16)
   //4th bit
   if (data & 8)
   //3rd bit
   if (data & 4)
   //2nd bit
   if (data & 2)
   //1st bit
      if (data & 1)
   output_high(CS);
   output_low(CS);
void init_lcd(int1 colormode)//colormode==0 8 bit
   {//mode ==0 send a command, mode==1 sends data
   unsigned int16 i;
   unsigned int8 x,y;
   output_low(_LCDPWR);//apply power to LCD
   delay_ms(250);
   output_low(CS);
   output_high(_reset);
   output_low(_reset);
   delay_ms(1);
   write_lcd(0, DISCTL);//display control
   write_LCD(1, 0x03);///original values
   write_LCD(1, 0x20);
   write_LCD(1, 0x0C);
   write_LCD(1, 0x00);
   write_lcd(0, NOP);//no op
   write_lcd(0, COMSCN);//common scan direction
   write_LCD(1, 0x01);
   write_lcd(0, OSCON);//oscillator on
   write_lcd(0, SLPOUT);//sleep out
   write_lcd(0, VOLCTR);//electronic volume control
   write_LCD(1, 0x05);//cares about lower 6 bits   V1 volume
   write_LCD(1, 0x01);//cares about lower 3 bits   1+Rb/Ra, supposed to specify "resistance ratio of internal resistor"
   write_lcd(0, PWRCTR);//power control
   write_LCD(1, 0x0f);//turn stuff on
   write_LCD(1, 0x64);
   write_lcd(0, DISINV);//inverse display
   write_lcd(0, DATCTL);//Data control
   write_LCD(1, 0x00);
   write_LCD(1, 0x00);
//   write_lcd(0, TMPGRD);//temp gradient
//   write_LCD(1, 0);//
   if (colormode == 0)//8 bit color
      write_LCD(1, 0x01);
      write_LCD(1, 0x02);//4096 colors
   write_LCD(1, 0x00);
      write_lcd(0, RGBSET8);//setup color lookup table
      //red
      write_LCD(1, 0);
      write_LCD(1, 2);
      write_LCD(1, 4);
      write_LCD(1, 6);
      write_LCD(1, 8);
      write_LCD(1, 10);
      write_LCD(1, 12);
      write_LCD(1, 15);
      //green
      write_LCD(1, 0);
      write_LCD(1, 2);
      write_LCD(1, 4);
      write_LCD(1, 6);
      write_LCD(1, 8);
      write_LCD(1, 10);
      write_LCD(1, 12);
      write_LCD(1, 15);
      //blue
      write_LCD(1, 0);
      write_LCD(1, 4);
      write_LCD(1, 9);
      write_LCD(1, 15);
   write_lcd(0, DISON);//display on
   delay_ms(300);
   for (i=0; i<150; i++)
      write_lcd(0, VOLUP);//changes contrast, find correct setting by trial and error
If anyone gets a chance to experiment and finds better init values do let us know.
Avery
newby
PostPosted: Fri Apr 14, 2006 8:06 am     Reply with quote
i found a few minutes for a quick and dirty test and after some adaptions it works also on a 18F2620 and 18F2680 !!!
The color doesnīt seem to be "stable" that means it takes some time (0.5 - 1s) until the color reaches the final color, i guess this has something to do with the contrast and temperature settings ?!?
As soon as i have had time to play around with tht init, i wll let you know !
Thanks a lot amcfall !
amcfall
PostPosted: Fri Apr 14, 2006 8:42 am     Reply with quote
One thing to mess around wioth is how many times you send VOLUP (the last thing we do in init_lcd). Unfortunately it's all trial and error. Originally I had a delay in that loop so you could judge the changes easier, but I guess I removed that.
Enjoy
Avery
newby
PostPosted: Sun Apr 16, 2006 8:32 am     Reply with quote
...this was a hard job !
Well, i spent about "1day" playing around with the VOLUP, but it didnīt change anything, there was no effect at all.
I tried a lot and finally my key issue was the DISCTL i had to change from your code
   write_LCD(1, 0x20);
   write_LCD(1, 0x0C);
   write_LCD(1, 0x00);
to
   write_LCD(1, 0x0C);
   write_LCD(1, 0x20);
   write_LCD(1, 0x0C);
   write_LCD(1, 0x00);
itīs only the 1st line which sets the clock dividing ratio, in the 2nd line 0x1F also functions but you can see some stripes if you take a closer look under a slight angle
this seems to me to give the best quality, with the above settings i am able to set the contrast and the colors are also OK !
amcfall
PostPosted: Tue Apr 18, 2006 9:48 am     Reply with quote
Great, as soon as my boards show up I'll try your modification. Out of curiousity, what kind of LCD do you have? I have the latest from Sparkfun, the one with the brown ribbon cable. I guess the green cables version has different settings even though both use the same Epson chip.
Avery
newby
PostPosted: Tue Apr 18, 2006 11:33 am     Reply with quote
I have "no idea" what type of LCD i have (i bought it at ebay), i only know that it is for the Nokia 6100 and has the green cables. Therefore i thought it has to be the epson controller - Bingo, the code works.
I also read in other forums that there is another epson controller around, the "S1D10605" which should be very rare and react similar to the philips - but still somehow different. I hope i donīt get one of these the next time i order.
awelch
PostPosted: Sun Sep 03, 2006 4:46 pm     Reply with quote
hey.. how did you guys wire up the sparkfun LCD to the PIC..?
you're using the 18 series chips? running at 3.3v? I want to hook it up to a 16F877 (it's all I have).. are the LCDs 5 volt signal tolerant?
thanks Very Happy
amcfall
PostPosted: Tue Sep 05, 2006 6:03 am     Reply with quote
thanks Very Happy
I made a custom board, although the Sparkfun breakout board would work also. No, the LCD is not 5V tolerant. I have used both 3.3v pics and a level shifter.
Avery
awelch
PostPosted: Tue Sep 05, 2006 7:56 am     Reply with quote
okay thanks..
That's what I thought and ordered some 74lvc125's to do the level shifting.. out of curiosity, which 3.3v pics did you use?
thanks again
Goto page 1, 2  Next
Page 1 of 2
