LCD
janiga
LCD
PostPosted: Mon Apr 10, 2006 4:39 pm     Reply with quote
How do I pass a type to the lcd.c function.
I am able to display characters by lcd_putc("\fTest") but if i assign a type it does not work.
Any suggestions?
Thanks!
#include "C:\Documents and Settings\Pedro\My Documents\Compilertests\NewProcessor\newlcd6.h"
#include <LCD.C>
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC                    //Internal RC Osc
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOPROTECT                //Code not protected from reading
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOCPD                    //No EE protection
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NODEBUG                  //No Debug mode for ICD
char n;
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_lcd(LCD_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_oscillator(OSC_4MHZ);
lcd_init();
n = 5;
WHILE(TRUE)
lcd_putc('\f');   /// Clear display
lcd_putc(n);
PostPosted: Mon Apr 10, 2006 4:44 pm     Reply with quote
Please don't start a new thread everytime you have an LCD question.
Just add the new question onto one of your existing LCD threads.
See this link for the answer to your current question:
http://www.ccsinfo.com/forum/viewtopic.php?t=19610
janiga
Thanks Again!
PostPosted: Mon Apr 10, 2006 4:53 pm     Reply with quote
It works fine with the code specified in thread!
Also sorry for the new thread, wont happen again.
