sprintf problem..........
prayami
PostPosted: Sun Apr 09, 2006 4:00 pm     Reply with quote
Hi.....I have CCS PCH compiler version 3.235.23.16 . And I am using
18F4525 microcontroller. I tried the following program but non of the
PIN_D4 to PIN_D7 goes high.
This code is to save float value into to char array. And I tried to check
the position of the dot in that array but there is no dot in that array.
Is it bug...??
As per I understand...the following code ...
sprintf(input_str,"%01.2f",0.71);
should result like this...
input_str[0] = '1'
input_str[1] = '7'
input_str[2] = '.'
input_str[3] = '0'
input_str[4] = '\0'
But it is not like that.....................
#include <18F4525.h>
#fuses H4,NOWDT,NOLVP,NOBROWNOUT,NOPBADEN,PUT,NOXINST,NOMCLR,NOLPT1OSC
#use delay(clock=40000000)
char input_str[5];
  set_tris_d(0x00);
  output_low(PIN_D4);
  output_low(PIN_D5);
  output_low(PIN_D6);
  output_low(PIN_D7);
  while(TRUE) {
      if( input_str[0] == '.' )
         output_high(PIN_D4);
         output_low(PIN_D4);
      if( input_str[1] == '.' )
         output_high(PIN_D5);
         output_low(PIN_D5);
      if( input_str[2] == '.' )
         output_high(PIN_D6);
         output_low(PIN_D6);
      if( input_str[3] == '.' )
         output_high(PIN_D7);
         output_low(PIN_D7);
  }//while(TRUE)
}//main
PostPosted: Sun Apr 09, 2006 4:31 pm     Reply with quote
In your version of the compiler, in the printf (or sprintf) format statement,
the "width" specifier must be greater than the "precision" specifier.
See the changes I've made in bold below. If you make that change
then you get the proper output:
string = 0.71
#include <18F4525.H>
char input_str[10];
sprintf(input_str,"%03.2f",0.71);
printf("string = %s\n\r", input_str);
In PCH vs. 3.249, your original code as posted, will work.
But with your older version, you have to do it like I've shown above.
