12F683 analog
mmprestine
12F683 analog
PostPosted: Fri Apr 07, 2006 8:56 am     Reply with quote
compiler version: 3.242
I have been working on a project that uses the sAN0 and sAN3 analog inputs on the 12F683 and seem to have found serveral discrepencies between the compiled code and the datasheet. Sample code below:
#include <12F683.h>
#device *=8 adc=10
#FUSES NOWDT                  //No Watch Dog Timer
#FUSES INTRC_IO               //Internal RC Osc, no CLKOUT
#FUSES NOCPD                  //No EE protection
#FUSES NOPROTECT              //Code not protected from reading
#FUSES NOMCLR                 //Master Clear pin used for I/O
#FUSES NOPUT                  //No Power Up Timer
#FUSES NOBROWNOUT             //No brownout reset
#FUSES IESO                   //Internal External Switch Over mode enabled
#FUSES FCMEN                  //Fail-safe clock monitor enabled
#use delay(clock=8000000)
#use rs232(baud=4800,xmit=PIN_A1,rcv=PIN_A2,parity=N,bits=8,errors)
//#priority EXT,TIMER0
#ZERO_RAM
   setup_oscillator(OSC_8MHZ);
    // initialize adc hardware
    setup_adc_ports(sAN3|VSS_VDD);
    set_adc_channel(sAN3);
   while (TRUE){
      printf( "Analog Data:%Lu\n\r", read_adc() );
this results in this ASM:
....................       // initialize adc hardware
....................       setup_adc_ports(sAN3|VSS_VDD);
03F9:  BCF    1F.6
03FA:  BSF    03.5
03FB:  BCF    1F.0
03FC:  BCF    1F.1
03FD:  BCF    1F.2
03FE:  BSF    1F.3
....................       setup_adc(ADC_CLOCK_INTERNAL);
03FF:  BSF    1F.4
0400:  BSF    1F.5
0401:  BCF    1F.6
0402:  BCF    03.5
0403:  BSF    1F.7
0404:  BSF    1F.0
In the data sheet to setup for sAN3 the control register 1F.2 and 1F.3 should be set. And the select regiester should be 9F and not 1F.
I am I correct about this?
Has any one used the analog on this chip and if so what compiler version?
Regards,
Matt
Humberto
PostPosted: Fri Apr 07, 2006 12:20 pm     Reply with quote
Well, this is an old subject and reason why I even see is between us.
It is an error in the constant definition in the 12F683.h file.
In the paragraph:
// Constants used in SETUP_ADC_PORTS()
Replace this lines
#define sAN0 1 //| GP0
#define sAN1 2 //| GP1
#define sAN2 4 //| GP2
#define sAN3 8 //| GP4
For this:
#define sAN0 0 //| GP0
#define sAN1 4 //| GP1
#define sAN2 8 //| GP2
#define sAN3 12 //| GP4
and the life will smile you.
Humberto
PostPosted: Fri Apr 07, 2006 12:31 pm     Reply with quote
Here is an explanation of the listing file:
00D6:  BCF    03.5    // Bank 0
00D7:  BCF    1F.6    // VCFG = 0
00D8:  BSF    03.5    // Bank 1
00D9:  BCF    1F.0    // AN0 = digital pin
00DA:  BCF    1F.1    // AN1 = digital pin
00DB:  BCF    1F.2    // AN2 = digital pin
00DC:  BSF    1F.3    // AN3 = Analog pin
00DD:  BSF    1F.4    // ADCS = 011 = use internal clock
00DE:  BSF    1F.5
00DF:  BCF    1F.6
00E0:  BCF    03.5    // Bank 0
00E1:  BSF    1F.7    // ADFM = 1  (right justify)
00E2:  BSF    1F.0    // ADON = 1
Also, the parameter you have used in the following line is not valid:
You must use numbers for the channels. It should be:
set_adc_channel(3);
This is in the manual.
mmprestine
PostPosted: Fri Apr 07, 2006 1:24 pm     Reply with quote
Thanks,
I will change it and give it a try. Strange that it compiles with the wrong parameter.
Matt
mmprestine
PostPosted: Fri Apr 07, 2006 1:51 pm     Reply with quote
Well as soon as I change the header file to Humberto's new defines and try to use analog 3 the serial does not function anymore. By serial I mean that I am using the external interrupt to parse serial data through a Max232. It appears to be affecting the external interrupt. Any thoughts on this?
PostPosted: Fri Apr 07, 2006 2:01 pm     Reply with quote
Put the #define statements back to the way they were in
the original 12F683.H file. Example:
Then do your A/D setup code like this:
setup_adc_ports(sAN3 | VSS_VDD);
set_adc_channel(3);
Humberto
PostPosted: Fri Apr 07, 2006 2:28 pm     Reply with quote
PCM Programmer you are right, sorry. It was an old issue.
Humberto
