Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
PIC & transceiver
Posted: Thu Apr 06, 2006 3:28 pm
I am thinking of using the Micrel MICRF505 RF transceiver. Has any one done this type before or is there another RF Transceiver that I should be looking at.
spec http://www.micrel.com/page.do?page=/product-info/MICRF50xDEV1.shtml
MICRF505DEV1 850MHz-950MHz +10dBm 38.4kbps -103dBm 9600-8-N-1 RF Test Bench FCC part 15.247
the DEV kit has a PIC micro 18LF4320 and source codes from microchip C18
ANdrew _________________ What has been learnt if you make the same mistake?
ak6dn
Joined: 08 Jan 2006 Posts: 23 Location: Saratoga, CA USA
Re: PIC & transceiver
Posted: Thu Apr 06, 2006 9:33 pm
Storic wrote:
ANdrew
If you are designing a production device, maybe Micrel is the way to go.
Otherwise look here for a good selection of low cost RF modules:
