Dude Guest
| KBHIT PROBLEM |
Posted: Tue Apr 04, 2006 8:47 am |
I have this code for my RS-232 receiver. My transmitter program sends
( A,10| ) with no braket but when I use kbhit I receive only ( A, ). If I remove ( if kbhit()==1 ) I receive ( A,10| ). Can anyone help finding out why there is only ( A, ) in the buffer when I use kbhit?
if(kbhit()==1)
for(i=0;Lecture[i-1]!='|';i++)
Lecture = getc();
Lecture[i]='\0';
lcd_gotoxy(21,1);
printf(LCD_PUTC,"%s",Lecture);
Thanks. |
mpfj
Posted: Wed Apr 05, 2006 7:47 am |
The kbhit() function returns the following ...
| Quote: | 0 (or FALSE) if getc() will need to wait for a character to come in,
1 (or TRUE) if a character is ready for getc() |
Note that it states *a* character, not *some* characters.
Therefore, you will need to perform a kbhit() check for each incoming character. |
Posted: Wed Apr 05, 2006 8:33 am |
Though true, that is not the problem. Once he is 'inside' the fetch loop, he stays there till the required character is detected for the end of string, and getc, will wait for each character in turn.
As I have posted to another thread, the problem is probably that the test fails on the first 'for' loop, when testing Lecture[0-1], which is outside the array, and could return anything. The addition of kbhit, probably results in some of the RAM containing different values, and 'shows up' this logic fault.
mpfj
Posted: Wed Apr 05, 2006 8:36 am |
| Code: | | for(i=0;Lecture[i-1]!='|';i++) |
Nice one ... can't believe I didn't spot it !!  |
