Problem with GSM and UART
Zvasas
PostPosted: Tue Apr 04, 2006 3:13 pm     Reply with quote
Hi all i have problem with connecting GSM to PIC.
I send data from PIC to GSM it'sall OK, but then i receiving data from GSM to PIC having problems, it's not corect data.
GSM sending
AT
OK
but i geting "PUHø" that is wrong ?
This is my code:
#include <16F628.h>
#include <string.h>
#use delay(clock=8000000)
#fuses hs, noprotect, nowdt, nolvp
#use rs232(baud=19200,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,stream=GSM)//Mobiliakoportas
#use rs232(baud=19200,parity=N,xmit=PIN_A3,rcv=PIN_A2,bits=8,stream=PC)//kompo portas
#define LED1 PIN_B4
#define LED2 PIN_B5
#define LED3 PIN_B6
#define BUT1 PIN_A0
#define BUT2 PIN_A1
const char SMSinit[] = "AT+CMGS=";        //duodama komanda kad bus pradeta siusti SMS
const char SMSinitEND[] = "\x0d";         //siunciama komanda AT+CMGS=XX kur XX yra bitu skaicius sekancio siuntimo
const char SMSStart[] = "0011000B91";     //pirmieji zinutes simboliai kurie nurodo zinutes tipa, numerio ilgi ir tt.
const char SMSbit[] = "0000AA";           //simboliai nurodantys zinute galiojimo laika ir tt.
const char SMSend[] = "\x1a\x0d";         //siunciame zinute <CRRL><Z>
const char ATDstart[] = "ATD+";
const char ATDEND[] = ";\x0d";
const char SMS[20] = "C526949AF5";              //zinutes tekstas (koduotas) siuo atveju "EMPTY"
const char SMSlenght[] = "05";                 //zinutes teksto ilgis "05" bus 5 simboliai ("0A" bus 10; 13 bus 19) simboliu
const char SMSnumber[] = "7360812481F7";      //telefono numeris y kuri bus siunciama zinute "37062546960" 'F'
const char SMSinitLNG[] = "18";                //zinute sudaro 13 + kiek sudaro zinutes tekstas
const char ATDnumber[] ="37061842187";                      //telefono numeris
int a,dial,smsas;
char simbolis;
char buferis[80] = "";
char atsakymas[] = "Kiaule";
int kintamasis = 0;
void init() { set_tris_a(0X0F);}          //nustatome RA_0,RA_1,RA_2,RA_3 kaip INPUT(iejimo)
void init_mobile()                        //Patikriname rysy su mobiliuojiu telefonu
char a,b;
loop:                                     //pradedame operacija "Loop"
 fprintf(PC,"AT\r\n");                        //siunciame komanda "AT"
    if(kbhit(PC)){a=fgetc(PC);}
    if(kbhit(PC)){b=fgetc(PC);}
    if(a=='O' && b=='K')                 //jeigu kintamasia a1=A o a2=T
    output_high(LED2);
    delay_ms(200);
    output_low(LED2);                   //kitu atveju sviesos dioda isjungeme
    delay_ms(200);
    goto loop;                            //kartojame nuo operacijos "Loop"
void gaudom()
simbolis=fgetc(PC);
if(simbolis==0x0A ||simbolis==0x0D){kintamasis=0; fprintf(PC,"\r\nAtsakymas yra - "); goto galas;}
buferis[kintamasis]=simbolis;
kintamasis++;
fputc(simbolis,PC);
galas:
if(kintamasis==0)
 if (strncmp(buferis,atsakymas,6)==0){fprintf(PC,"Teisingas\r\n");} else {fprintf(PC,"Neteisingas\r\n");}
 strcpy(buferis,"");
void gaudom_gsm()
simbolis=fgetc(GSM);
if(simbolis==0x0A ||simbolis==0x0D){} else fputc(simbolis,PC);
void Call()                               //Skambinimas
fprintf(GSM,ATDstart);
fprintf(GSM,ATDnumber);
fprintf(GSM,ATDEND);
Void main()
int a=0;
init();
output_high(LED1);
output_high(LED2);
output_high(LED3);
output_low(LED1);
output_low(LED2);
output_low(LED3);
pradzia:
 //if(kbhit(PC)){output_high(LED3);gaudom(); goto pradzia;} else {output_low(LED3);}
 if(kbhit(GSM)){gaudom_gsm(); goto pradzia;}
 if(!input(BUT1)){ fprintf(PC,"Patikrinimas\r\n");}
 if(!input(BUT2) && a==0){fprintf(PC,"Paspaustas AT\r\n"); fprintf(GSM,"AT\r\n");a=1;} else if(input(BUT2)) {a=0;}
goto pradzia;
GSM phone connected directly.
