problem in Blinking a character in t6963c graphics display
Rajesh
PostPosted: Tue Apr 04, 2006 11:52 am     Reply with quote
Hi Friends,
I am working on t6963c graphics display system, I am finding problem in blinking a character on display, I have tried all methods but i was not able to get solution , I am using AT89S8252 Microcontroller,If any one of u have solution please reply back
Rajesh
treitmey
PostPosted: Tue Apr 04, 2006 1:26 pm     Reply with quote
Your not in the right forum. but...
You need to go to Text Attribute mode.
Then set the address to graphics area.
Then set the attribute.
The attrib at graphics location 0 affects the text at text location 0
I have it working right now in front of me. hantronix hdm64gs24L
#include <18f452.h>
#use delay(clock=40000000)
#fuses h4,nowdt,noprotect,nolvp
#include <LCD_T6963C.c>
#case
#use rs232(baud=19200,xmit=PIN_C0,invert,stream=DEBUG)
#zero_ram
//---------------- MAIN --------------------
void main(void){
  int8 key;
  glcd_init();
  glcd_WriteCmd0(LCDDispMode|LCDDisp_TXT);
  glcd_WriteCmd0(LCDModeSet|LCDMode_TA);
  DispScn(0);
  glcd_WriteCmd2(LCDTxtAdr(0,0,0),LCDSetPtr);//LCDTxtAdr(screen,x,y)
  fprintf(DEBUG,   "Start..");
  printf(glcd_putc,"123456789ABCD");
  glcd_WriteCmd2(GraphicsHome,LCDSetPtr);
  glcd_WriteCmd1(8,WR_INC);//blink of normal display
  glcd_WriteCmd1(0,WR_INC);
  fprintf(DEBUG,"done\n\r");
  while(1){
Marcio
Difficulty LCD HDM128GS24Y-1
PostPosted: Tue Jun 20, 2006 6:52 am     Reply with quote
Good morning
Excuse the interference.
I am trying to develop an application with the hantronix display " HDM128GS24Y-1 " with the T6963.
I am having a lot of difficulty Sad Sad to do the basic routines of control (Example: Reset, to Print ONE Pixel, to Write a character , or Text).
Could you supply the condigo that makes these controls in language C? I thank if it can help me. I am working 2 months with LCD and I always have new situations that are not real.
The documentations that I find in the internet only make reference in " Assembler ". I use DSP " with language C ". It is very difficult to find support...
Can you help? Or do inform a site that has an application using the language C for this HDM128GS24Y-1 LCD.?
Attn
Márcio - Brazil
Rajesh wrote:
Hi Friends,
Rajesh
butterfly
PostPosted: Tue Jun 20, 2006 7:57 am     Reply with quote
i'm working with t6963c
and have steel problems for 2 weeks
but maybe ir can help you for code...
http://www.picant.com/c2c/examples/t6963/t6963.c.html
http://www.picant.com/c2c/examples/t6963/t6963.h.html
haveyou make it work in graphic mode?
good luck
treitmey
PostPosted: Tue Jun 20, 2006 8:33 am     Reply with quote
DID YOU LOOK AT THE DRIVERS AND SAMPLE CODE IN THE CODE LIBRARY?
http://www.ccsinfo.com/forum/viewtopic.php?t=19957
