Update program on rs-485
Francesco
PostPosted: Fri Mar 31, 2006 1:46 am     Reply with quote
Hello
Can i update my program on PIC18F... on rs485 , How can I do it.
Thank you.
Question
Mark
PostPosted: Fri Mar 31, 2006 7:21 am     Reply with quote
Yes. Just convert one of the bootloaders that is using RS232. You shouldn't need to change much. You just need to handle the transmit/receive enable/disable.
Francesco
Example?
PostPosted: Fri Mar 31, 2006 7:28 am     Reply with quote
Thanks for your answer , but can I read the some example?
Mark
PostPosted: Fri Mar 31, 2006 7:33 am     Reply with quote
Look in your examples folder. There is an example of a bootloader there. Also you will find a EX_RS232_485.c file. Study both programs.
Francesco
PostPosted: Fri Mar 31, 2006 7:48 am     Reply with quote
Hello
I look in my ex-folder but i can't find it, my compiler version is PCB 3.180.
Is it old?
Thanks.
Mark
PostPosted: Fri Mar 31, 2006 7:49 am     Reply with quote
What pic are you trying to use?
Francesco
PostPosted: Fri Mar 31, 2006 7:53 am     Reply with quote
I want use 18F6520 or 16F876A.
Mark
PostPosted: Fri Mar 31, 2006 12:25 pm     Reply with quote
For PIC16 you need the PCM compiler
For PIC18 you need the PCH compiler
Of course the PCWH contains all the compilers.
Francesco
PostPosted: Mon Apr 03, 2006 9:20 am     Reply with quote
I have :
IDE versione 3.40
PCB 3.180
PCM 3.180
PCH 3.180
Mark
PostPosted: Mon Apr 03, 2006 10:16 am     Reply with quote
If you don't have it, then upgrade. You might try and download the trial version. I am not sure what examples they provide with it.
PostPosted: Mon Apr 03, 2006 12:03 pm     Reply with quote
Email CCS support and ask them for the RS485 example and driver files.
RS485.C
EX_RS485.C
EX_RS232_485.C
Give them your name and compiler registration number. If you're a
registered owner, then they might email you the files.
PostPosted: Tue Apr 04, 2006 2:36 am     Reply with quote
OK.
