my problem is, that the math libary use a "RAD" calculation for sin and cos. How i can get the result in "DEG"
Anyone who know´s
Thanks Thorsten
Charlie U
Joined: 09 Sep 2003 Posts: 183 Location: Somewhere under water in the Great Lakes
Posted: Sun Apr 02, 2006 9:17 am
The sin and cosine functions use angles as arguments and they return a value between +1.0 and -1.0. Most calculators either take degrees as the argument or can be changed from degrees to radians. The conversion is 360 degrees equals 2*pi radians. So to convert degrees to radians divide your argument (in degrees) by 360 and multiply by 2*pi. pi = 3.14159265 and 2*pi = 6.28318531.
As an example we'll convert 45 degrees to radians:
