Problems with Division Result = 0.0000000 when debugging
PostPosted: Sat Apr 01, 2006 2:20 am     Reply with quote
Hi all,
I have following problem: the division does not work. The result is always 0. I have a ICD2 module with the testboard. Connecting,and debugging is working, I can set breakpoints... but always 0!
The value from adc is greater than 0. Do I have to include something like <math.h>? I tried this but doesn´t work
Here my short program:
#include<16F877.h>
#device adc=10
long PULSWEITE_LOW;
long PULSWEITE_HIGH;
long DIFFERENZ;
float TESTZAHL;
float TEILER;
setup_ADC(ADC_CLOCK_INTERNAL);
setup_ADC_PORTS(RA0_ANALOG);
set_adc_channel(0);
PULSWEITE_LOW = 0;
PULSWEITE_HIGH = 0;
TEILER = 0;
TESTZAHL = 0;
for(;;)
PULSWEITE_LOW = read_adc();
DIFFERENZ = PULSWEITE_LOW - PULSWEITE_HIGH;
TEILER = 255 / DIFFERENZ;
TESTZAHL = TEILER * 255;
PostPosted: Sat Apr 01, 2006 3:14 am     Reply with quote
You have to tell the compiler to do floating point division.
In your code it's doing integer division, so that explains why you get 0.
The compiler will do floating point math if at least one of the numbers
is floating point in the division equation. So you should make the "255"
into a floating point number as shown below in bold:
TEILER = 255.0 / DIFFERENZ;
PostPosted: Sat Apr 01, 2006 4:19 am     Reply with quote
Jipieee, yes this works! Such a simple error- a huge fault
Thanks a lot!!
migsantiago
PostPosted: Sat Apr 01, 2006 8:07 pm     Reply with quote
You can also use:
TEILER = (float)255 / DIFFERENZ;
Casting forces CCS to get a float type value.
